I have several Dual Relays on a Hub (Called Slave) and I use hub Mesh to make them appear on my main Hub (Called Master)
The Child Devices work fine when I control them directly from the Devices tab on either my Master or Slave Hubs and I can see this in the event log.
However, when I try to integrate these devices into my Webcore pistons they fail to work about 50% of the time. They usually come on fine but won't go off - but not always
Does anyone have any suggestions to improve this situation?
For instance, should I turn off the main device sync or will this stop the child devices from syncing as well!
Is this overloading the Hub Meshing system!
Can I change an execution policy in Webcore to overcome this!
