Updates don't complete and renders Hubitat unavailable
Hi Guys,
After the last three updates I have done on my C7 the hub gets stuck in reboot and never completes. I got the tip from you guys to fix this by doing a network reset on the hub which sorts out the issue, but also gives the hub a new IP-address. But it works.
Why does this suddenly happen and is there a way to not make this happen after every update?
Cheers,
No idea why it is getting stuck on the reboot. But, if it is changing the IP everytime you press the network reset, then you need to reserve the IP in your router.
As @tray_e Reserve the IP. Sounds like an IP conflict.
