What is the forecastIcon data on the driver?
Just flipped to my MacOS dashboard to see what time it was at your house, and I noticed how ridiculous the bleeding sun icon is on the Yahoo weather widget
cloudy
The thing to do is compare the apixu 'forecastIcon' to the WU one.
If they are the same then in theory they should show the same icon.
It's 7:42 AM here
I trust you've had your tea? If not, this can wait
This is what Apixu shows...
- forecastIcon : nt_cloudy.
That’s because apixu differentiates between night and day but wu doesn’t seem to
In the weewx driver I’ve mapped the apixu icons to day and night so that should be ok.
I have guests this weekend so I’ll have a look on monday if there is anything I can do to try and get wu to report day/night
Enjoy! Time for me to sleep before the sun's up
So I was going through all my apps/drivers and seeing if there were any updates...
Noticed this one had an update, so I went ahead and updated my daily.json and then the driver. Now I'm getting an error...
Trying different stuff here... one thing I noticed is that I can copy the new json over and it looks OK. Save it, open it up and it looks good. No data but everything looks ok. Then I wait for it to update. After it updates, I open up the json again and the new stuff is gone in the 'sinceMidnight' section.
I've updated the daily.json and the Hubitat driver... Am I missing something?
I’m not near my pc at the moment so can’t do a lot (ipad coding isn’t pretty!)
There is a problem with the json file I think.
I think there is an extra ‘ } ‘ on line 51
Try removing that and save.
I think that might fix it.
Andy
No luck. I tried it a bunch of different ways and each time when weewx would update, it would have blank spaces in the json like it found nothing to put there.
What I was successful with is going into your new code and removing the 4 min and max sections. So now at least I don't get the errors and my Weather Switch devices will still work.
Hi Bryan
so did you remove them from the json file?
No, that's what I can't figure out. I change it, check that it is changed...then weewx updates and it's gone.
This is my latest try... your original code this time (I've tried 5 different versions) I'll update in a minute with what it changes it to.
Bryan
can you do me a favour?
can you 'browse' to the json file with a browser so you can see the output (after it has updated) please
I want to see the actual output from the json file.
It may be that the values are just 'null' so I can compensate for that
Andy
That's really weird!
weewx should not be able to update/edit the json file...
I have no idea what is happening here..
This is the output from my json file...
"title":"Current Values",
"location":"South Hetton",
"time":"22/10/18 00:45:00",
"lat":"54° 47.88' N",
"lon":"001° 24.41' W",
"alt":"328 feet",
"hardware":"observer",
"uptime":"40 days, 11 hours, 28 minutes",
"serverUptime":"40 days, 10 hours, 41 minutes",
"weewxVersion":"3.8.0",
"stats": {
"current": {
"outTemp":"6.1°C",
"windchill":"6.1°C",
"heatIndex":"6.1°C",
"dewpoint":"3.0°C",
"humidity":"81%",
"insideHumidity":"48%",
"barometer":"1015.7 mbar",
"barometerTrendDelta":"3 hours",
"barometerTrendData":"1.2 mbar",
"windSpeed":"0 mph",
"windDir":"245°",
"windDirText":"WSW",
"windGust":"5 mph",
"windGustDir":" N/A",
"rainRate":"0.0 mm/hr",
"UV":"0.0",
"solarRadiation":"0 W/m²",
"insideTemp":"21.9°C"
"sinceMidnight": {
"rainSum":"0.0 mm",
"maxtemptoday":"6.6°C",
"mintemptoday":"6.0°C",
"maxinsidetemptoday":"22.0°C",
"mininsidetemptoday":"21.9°C"
"almanac":{
"sun":{
"startCivilTwilight":"07:10:09",
"sunrise":"07:47:45",
"transit":"12:50:06",
"sunset":"17:51:32",
"endCivilTwilight":"18:29:05",
"azimuth":"358.2°",
"altitude":"-46.1°",
"rightAscension":"206.5°",
"declination":"-10.9°",
"equinox":"20/03/19 21:58:31",
"solstice":"21/12/18 22:22:34"
"moon":{
"rise":"17:39:19",
"transit":"23:38:07",
"set":"04:37:44",
"azimuth":"210.2°",
"altitude":"25.1°",
"rightAscension":"357.9°",
"declination":"-6.0°",
"fullMoon":"24/10/18 17:45:11",
"newMoon":"07/11/18 16:02:03",
"phase":"Waxing gibbous",
"fullness":"92%"
I've completely deleted the file and recreated it too. Could it be getting the template from somewhere else?
I wonder if I added additional things to the config files in weewx??
I did this so long ago I don't remember
