The daily.json.tmpl in the image should be the same as the one posted (I think, as I haven’t loaded that image since I posted it)
But certainly the posted file should work ok.
I’m not near my pc at the moment so as soon as I am I’ll login to my Pi and copy the file.
In my code I am looking for ‘kph’ and I see from your output your server is sending ‘km/h’
As my server sends data in mph, mine would work but yours won’t
That’s why the logs didn’t show any conversion or confirmation for wind speed or gust speed.
The code &# 1 7 6 ; C is just converted to °C by the web browser
I strip this off before calculation etc then put it back on again if the units are enabled
It works. I did a find and replace, which worked everywhere expect two lines regarding conversion where the / wasn't valid. I'll of course use your modified code when it's ready, but you are correct. I can can see wind speed and gust now!
I'm working on a summary - similar to the one in the custom WU driver but using the data from weewx AND the external source.
It's a bit of a pain because the externals report differently
I'll get there (when I get a chance)
Guys New Version - 2.2.0
I have added support for daily Min/Max temperatures (inside & outside)
NOTE: This requires additions to your daily.json.tmpl if you want to use these features
You need to add a couple of lines to your daily.json.tmpl under the "sinceMidnight" section.
So that it looks like this:
(I have also uploaded a new version of daily.json.tmpl to my GitHub repository )
This will probably be one of the last additions to this driver as I'm struggling to find time to work on this along with all the other stuff I'm supporting.
When I get the chance, I'll add these attributes as triggers for Weather Switch
Moving the discusson over here so were're not taking over @bangali 's post with discussion about your driver.
I'm just really learning how these work in a dashboard for the first time, since I wasn't using HE Dashboard. I'm not sure what's correct. It was just an assumption on my part of how that switch worked with your driver, vs what I was seeing from @bangali 's driver. It is mostly cloudy right now and that's what his is showing. I guess I assumed that if I changed the switch from forecast to current, the Icon would follow.
There's a bit of an odd discrepancy with this driver I've been meaning to ask you about. I see this somewhat on the WU app as well, but not on the WU web page for my station. It shows "The Beaches" which is what it shows on the app, but then shows the custom name I added "The Beach" as well. On the web, it just says, "The Beach". But it's not just the name that is different. For instance, the WU site for my station show's 79% humidity, but the driver is pulling in 82%.
I've entered my exact GPS coordinates, and I also tried entering the coordinates as they appear on my stations WU page. No change. I also tried entering my station ID, but I don't know if that's supported.
