The code I gave you should remove this error as the app is looking for a variable ‘msgDelay’ which is used for everything except time. (Hence setting it to 0 if not set elsewhere)
I only have an ipad in front of me at the moment so it’s difficult to debug.
I’ll try and have a look in the morning.
@cuboy29
Ok.
The error still relates to the same missing variable.
The code I gave you yesterday should have fixed this
The restrictions page is a little bit misleading and should really be something like
‘Show restrictions’ rather that turn them on/off
I’ll have to have a rethink on the wording.
So, the app looks for the settings, if they are filled in then the restriction will apply.
So if you remove the start and end times that you filled in the restriction will be removed.
I know that there is an issue with the playing of Mp3s and a few other bugs.
When I return from from my little vacation (I’m off diving in Malta tomorrow) I’ll finish the code and release a new version.
Please bear with me for a week or so.
@halfrican.ak
Mark, did you try adding the code?
Did that work for you?
EDIT: BTW You need to save the app after making the code changes
@halfrican.ak
Sorry Mark no that is not the case
What I'm saying is if you switch on the restriction it only exposes the settings.
If you just want particular days of the week then just select them
If you decide you don't want days of the week (after configuring them) then you can't just switch the restriction off. You need to deselect the days.
Both Weather Switch and Message Central will be getting ‘alerts’ as soon as I can get to it.
I’m on holiday at the moment and will look at this in a week or so.
The delay between messages is in minutes
This is really only if you want to calm down a device that is constantly reporting.
Like my tumble dryer..
Even after it finishes it fires up every 2-3 minutes to stop the clothes creasing...
I set it to 30 so if I don't empty and turn off I only get reminded every 30 minutes.
I will stress though THIS IS NOT A REPEAT MESSAGE FEATURE
If the device doesn't report again then you will not get repeat messages
Ashamed to say that I am not using Message Central, yet.... So, please forgive me if this idea is already built-into your App...
Since Message Central obviously can tell when a new version of software is available, maybe it could optionally send a Notification once a day/week/month to a device that supports Notification (like a Pushover device.) This way a user would not even have to open the App to know a new version exists. They would get a nice gentle reminder on their phone/tablet.
One of these days I need to install this App and try it out! It would help if I had some real TTS devices other than my Google Assistant Relay.
Dan
that's quite a good idea.
It should be easy enough to implement, I just need somewhere to put the inputs etc.
Hmmm..
Two good suggestions.. I'll have a think about this
Testing the new update code and pushover for apps now..
Seems to work well except providing a 'clickable' link
Using the standard html link code only seems to refresh the page and not open a new link
