[UPDATED] - Message Central - Make your home speak
community_app
#426
We can still get messages, just not custom, random messages, but do appreciate the personal pride in play :trophy:
#427
Guys
Try hitting the 'check for update' button in a child :slight_smile:
Have a play and check if this works for you.. seems to be ok but I haven't tested everything.
Andy
#428
You now have 4 groups of up to 10 phrases in each group ..
If you try and configure 11 it won't work :slight_smile:
#429
Nice, works great for me!
#430
Once I’d worked it out for the 1st one it was easy enough to duplicate for the other groups :slight_smile:
#431
Drew
Thank you very much for your generous donation, gratefully received and appreciated! :slight_smile:
Andy
#432
I read this in another thread and came back here because I thought this was worth trying out :slight_smile: I think it is what V12.6.0 change did to add this, right? I want to try to make it work with my Sonos.
#433
You can use MC for this or use ‘check open windows’.
Andy
#434
I don’t believe the restrict by switch is working.
I have a MC that is supposed to play a message when the front door is open but it is restricted if Front Door Timer is ‘On’.
When I open the door and front door timer is on... I hear the message. Here are the logs.
[    app:2132](http://192.168.7.201/logs#app2132)2018-12-23 02:48:59.965 pm [debug](http://192.168.7.201/installedapp/configure/2132)ENTRYWAY_FRONT_DOOR (App Version: 13.7.0) - Timer 1 reset - state.timer1 = true - Messages allowed
    [app:2132](http://192.168.7.201/logs#app2132)2018-12-23 02:48:59.840 pm [debug](http://192.168.7.201/installedapp/configure/2132)ENTRYWAY_FRONT_DOOR (App Version: 13.7.0) - Waiting for 0 seconds before resetting timer1 to allow further messages
    [app:2132](http://192.168.7.201/logs#app2132)2018-12-23 02:48:59.837 pm [debug](http://192.168.7.201/installedapp/configure/2132)ENTRYWAY_FRONT_DOOR (App Version: 13.7.0) - state.msgDelay = 0
    [app:2132](http://192.168.7.201/logs#app2132)2018-12-23 02:48:53.641 pm [debug](http://192.168.7.201/installedapp/configure/2132)ENTRYWAY_FRONT_DOOR (App Version: 13.7.0) - msg2 is empty so nothing to say..
    [app:2132](http://192.168.7.201/logs#app2132)2018-12-23 02:48:53.639 pm [debug](http://192.168.7.201/installedapp/configure/2132)ENTRYWAY_FRONT_DOOR (App Version: 13.7.0) - Continue... talkswitch. - state.msgNow = twoNow
    [app:2132](http://192.168.7.201/logs#app2132)2018-12-23 02:48:50.589 pm [debug](http://192.168.7.201/installedapp/configure/2132)ENTRYWAY_FRONT_DOOR (App Version: 13.7.0) - Speaker(s) in use: [Living Alexa Sonos, Kitchen Overhead Sonos] - waiting 3 seconds before continuing...
    [app:2132](http://192.168.7.201/logs#app2132)2018-12-23 02:48:50.039 pm [debug](http://192.168.7.201/installedapp/configure/2132)ENTRYWAY_FRONT_DOOR (App Version: 13.7.0) - No 'quiet time' settings...Multi Volume Not used - setting volume of all speakers to 40 - state.volume = 40
    [app:2132](http://192.168.7.201/logs#app2132)2018-12-23 02:48:48.556 pm [debug](http://192.168.7.201/installedapp/configure/2132)ENTRYWAY_FRONT_DOOR (App Version: 13.7.0) - state.multiVolumeSlots = false
    [app:2132](http://192.168.7.201/logs#app2132)2018-12-23 02:48:48.551 pm [debug](http://192.168.7.201/installedapp/configure/2132)ENTRYWAY_FRONT_DOOR (App Version: 13.7.0) - Calling.. CheckVolume
    [app:2132](http://192.168.7.201/logs#app2132)2018-12-23 02:48:48.548 pm [debug](http://192.168.7.201/installedapp/configure/2132)ENTRYWAY_FRONT_DOOR (App Version: 13.7.0) - [Entryway Front Door ] is closed
    [app:2132](http://192.168.7.201/logs#app2132)2018-12-23 02:48:48.537 pm [debug](http://192.168.7.201/installedapp/configure/2132)ENTRYWAY_FRONT_DOOR (App Version: 13.7.0) - checkallow complete - state.allAllow = true
    [app:2132](http://192.168.7.201/logs#app2132)2018-12-23 02:48:48.533 pm [debug](http://192.168.7.201/installedapp/configure/2132)ENTRYWAY_FRONT_DOOR (App Version: 13.7.0) - Time is ok so can continue...
    [app:2132](http://192.168.7.201/logs#app2132)2018-12-23 02:48:48.521 pm [debug](http://192.168.7.201/installedapp/configure/2132)ENTRYWAY_FRONT_DOOR (App Version: 13.7.0) - Checking for any time restrictions
    [app:2132](http://192.168.7.201/logs#app2132)2018-12-23 02:48:48.517 pm [debug](http://192.168.7.201/installedapp/configure/2132)ENTRYWAY_FRONT_DOOR (App Version: 13.7.0) - CheckAllow - Continue - App NOT paused
    [app:2132](http://192.168.7.201/logs#app2132)2018-12-23 02:48:48.512 pm [debug](http://192.168.7.201/installedapp/configure/2132)ENTRYWAY_FRONT_DOOR (App Version: 13.7.0) - Checking for any restrictions...
    [app:2132](http://192.168.7.201/logs#app2132)2018-12-23 02:48:47.721 pm [debug](http://192.168.7.201/installedapp/configure/2132)ENTRYWAY_FRONT_DOOR (App Version: 13.7.0) - All OK! - Playing message 1: 'good afternoon. it's 71.42 degrees outside. you look very nice today . '
    [app:2132](http://192.168.7.201/logs#app2132)2018-12-23 02:48:47.719 pm [debug](http://192.168.7.201/installedapp/configure/2132)ENTRYWAY_FRONT_DOOR (App Version: 13.7.0) - 2nd Stage Compile (Post weather processing) = good afternoon. it's 71.42 degrees outside. you look very nice today .
    [app:2132](http://192.168.7.201/logs#app2132)2018-12-23 02:48:47.717 pm [debug](http://192.168.7.201/installedapp/configure/2132)ENTRYWAY_FRONT_DOOR (App Version: 13.7.0) - Running convertWeatherMessage... Converting weather message to English (If weather requested)...
    [app:2132](http://192.168.7.201/logs#app2132)2018-12-23 02:48:47.716 pm [debug](http://192.168.7.201/installedapp/configure/2132)ENTRYWAY_FRONT_DOOR (App Version: 13.7.0) - 1st Stage Compile (Pre weather processing) = GOOD AFTERNOON. it's 71.42 degrees outside. you look very nice today .
    [app:2132](http://192.168.7.201/logs#app2132)2018-12-23 02:48:47.714 pm [debug](http://192.168.7.201/installedapp/configure/2132)ENTRYWAY_FRONT_DOOR (App Version: 13.7.0) - Greeting = GOOD AFTERNOON
    [app:2132](http://192.168.7.201/logs#app2132)2018-12-23 02:48:47.712 pm [debug](http://192.168.7.201/installedapp/configure/2132)ENTRYWAY_FRONT_DOOR (App Version: 13.7.0) - timeampm = pm - timehh = 2
    [app:2132](http://192.168.7.201/logs#app2132)2018-12-23 02:48:47.710 pm [debug](http://192.168.7.201/installedapp/configure/2132)ENTRYWAY_FRONT_DOOR (App Version: 13.7.0) - timeHH = 2
    [app:2132](http://192.168.7.201/logs#app2132)2018-12-23 02:48:47.708 pm [debug](http://192.168.7.201/installedapp/configure/2132)ENTRYWAY_FRONT_DOOR (App Version: 13.7.0) - randomKey1 = 2
    [app:2132](http://192.168.7.201/logs#app2132)2018-12-23 02:48:47.706 pm [debug](http://192.168.7.201/installedapp/configure/2132)ENTRYWAY_FRONT_DOOR (App Version: 13.7.0) - MaxRandom1 = 4
    [app:2132](http://192.168.7.201/logs#app2132)2018-12-23 02:48:47.704 pm [debug](http://192.168.7.201/installedapp/configure/2132)ENTRYWAY_FRONT_DOOR (App Version: 13.7.0) - msgComp = %greeting%. it's %temp% degrees outside. %group1%.
    [app:2132](http://192.168.7.201/logs#app2132)2018-12-23 02:48:47.702 pm [debug](http://192.168.7.201/installedapp/configure/2132)ENTRYWAY_FRONT_DOOR (App Version: 13.7.0) - compileMsg - msg = %greeting%. It's %temp% degrees outside. %group1%.
    [app:2132](http://192.168.7.201/logs#app2132)2018-12-23 02:48:47.700 pm [debug](http://192.168.7.201/installedapp/configure/2132)ENTRYWAY_FRONT_DOOR (App Version: 13.7.0) - Calling.. CompileMsg
    [app:2132](http://192.168.7.201/logs#app2132)2018-12-23 02:48:47.698 pm [debug](http://192.168.7.201/installedapp/configure/2132)ENTRYWAY_FRONT_DOOR (App Version: 13.7.0) - Continue... talkswitch. - state.msgNow = oneNow
    [app:2132](http://192.168.7.201/logs#app2132)2018-12-23 02:48:44.655 pm [debug](http://192.168.7.201/installedapp/configure/2132)ENTRYWAY_FRONT_DOOR (App Version: 13.7.0) - Speaker(s) in use: [Living Alexa Sonos, Kitchen Overhead Sonos] - waiting 3 seconds before continuing...
    [app:2132](http://192.168.7.201/logs#app2132)2018-12-23 02:48:43.388 pm [debug](http://192.168.7.201/installedapp/configure/2132)ENTRYWAY_FRONT_DOOR (App Version: 13.7.0) - No 'quiet time' settings...Multi Volume Not used - setting volume of all speakers to 40 - state.volume = 40
#435
Did you toggle the switch after saving the app?
Hubitat.uk/options.htm
Look at the options for the external switch
Andy
#436
Got it.
So this log means the message will NOT play
pm[debug](http://192.168.7.201/installedapp/configure/2132)ENTRYWAY_FRONT_DOOR (App Version: 13.7.0) - Allow by switch is false
#437
Correct.
It needs to say "allow by switch is true' for the app to be allowed to run (if using this restriction)
Andy
#438
Any chance that multiple selection of presence sensors can be allowed to trigger message?
#439
Have a look at 'Presence Central'
#440
No option to use SpeechSynth device with "presence central" :frowning:
#441
No there isn't,
However, I use Presence Central to trigger a virtual presence/switch based on a group action (Using my virtual presence plus device driver - This makes a sensor also a switch)
Then I trigger the message in Message Central with the switch
#442
Has anyone tested this with the new chromecast "speaker" support?
#443
I'm trying... Not having luck though...
#444
Ah - it works, but you have select the message type as "Pushover Message", not speech synthesis. (This is literally my first time using MC)
#445
There is probably an issue with the speech synth side at the moment, someone else reported an issue today.
I’ll have a proper look in the next few days to track down the problem.
Off out to dinner right now :slight_smile:
BTW
If you try it with speech synth can you collect any error logs please?
That way I can trace the problem as this should work with speech synth
Andy
