[UPDATED] iPhone WiFi Presence Sensor
I've got the family's Android Pixel phones reporting via the Hubitat app, Alexa presence, and Owntracks, and I wanted to see if I could throw the "iPhone" WiFi Presence Sensor into the mix to generate Combined Presence.
The main issue I ran into during setup was assigning a static IP to each phone in our router. It's not an impossibility, but we use a block of static IP addresses on our LAN for other reasons and a mobile device that comes and goes wouldn't play so well being assigned that way.
My first thought was to use the phone's unique and static ipv6 address instead of a static ipv4 address, passing it as a string in square brackets - but that just resulted in an error from asynchttpGet in the logs:
debug Steve's Pixel WiFi: httpGetCallback({"headers":null,"warningMessages":[],"status":408,"errorMessage":"Connect to [fe80::6435:9b15:9ad8:4b0d]:80 [/fe80:0:0:0:6435:9b15:9ad8:4b0d] failed: Invalid argument (connect failed)","errorData":null}, data)
Should an ipv6 address enclosed in square brackets qualify as a valid URI for asynchhttpGet and similar Http calls? I only drilled down as far as the java.net.URI class, whose methods seem to accomodate ipv6 addresses in this format. I have tried entering the address with and without square brackets, and with and without compressed sections of 0000 blocks.
So where is the fail occurring when trying to register ipv6 addresses for our mobile phones in "iPhone" WiFi Presence Sensor ?
I'm not the author, but I looked at the code itself. It needs an actual browser useable IP address, because it is trying to contact the phone using http and then looking for a "connection refused" message. Since an alphanumeric mac address cannot be used in a browser, it cannot be used in this presence sensor.
	asynchttpGet("httpGetCallback", [
		uri: "http://${ipAddress}/",
        timeout: 10
Not sure what router you use. I'm running an Eero mesh, and it has worked well for several years to assign IP reservations to our phones. The phones still request IP from the routers DHCP, but the Eero always assigns them the same one.
The only hiccup I could see is if they were allowing the phones to use random MAC's. You have to toggle off Private Address so that it will use the same MAC everytime it connects to that network.
Yes, this is necessary.
Where do you get the contents of iPhoneWiFiPresenceSensor.groovy? I tried going on GitHub, but no matter what I search for, I keep getting "Your search did not match any packages." Also, there is no option for "Virtual Device" under the Device type. I selected Virtual switch.
The link is in the first post of this thread. A more direct link to the Groovy code is Hubitat-iPhone-Presence-Sensor/iphoneWiFiPresenceSensor.groovy at master ¡ joelwetzel/Hubitat-iPhone-Presence-Sensor ¡ GitHub.
Thanks. I completely missed that on first read. My link color was set to yellow and it just washed out. Great driver!!
So I am having a problem with my iPhone when trying to assign a static IP. I assigned the same IP address as the phone was assigned in Automatic mode, but when I save the Manual setting, the Wi-Fi symbol disappears and the phone reports no Wi-Fi when trying to access the internet. What am I missing?
How did you try to assign the IP address to the phone?
In your router’s interface (preferred) or from the iPhone’s WiFi settings screen?
I did it from the wi-fi settings. I read that somewhere in the bowels of this post.
The only thing you’ll want to change in your iPhone’s WiFi settings is to set private WiFi to off for your home network.
The iPhone should continue to use DHCP to request an IP address from your router. In the iPhone’s WiFi settings, that’s referred to as “automatic” for IP address assignment.
In your router’s settings, add a DHCP reservation for your iPhone’s MAC address. That will prevent the IP address from changing.
Changing other settings on the iPhone to establish a static IP is usually just asking for unnecessary complications unless you’re very knowledgeable with IP networking concepts.
ETA: Which router are you using at home?
I have the Netgear 15 router. I did find the link for reserving IP addresses in LAN Setup in the router interface. I clicked on the IP Addresses currently occupied by the 3 iphones in our house and left the iphones in Automatic mode. Now it works reliably well. When we leave and return, or even turn Wi-Fi OFF and back to ON on the iPhones, the IP address reserved for the respective iPhone is assigned and the Wi-Fi presence sensor device driver works as advertised. Thank you for pointing me down the right path!
Yeah this is key, if you don't the IPhone will change your MAC address each time it connects. Then your router will assign a different IP.
I spent a couple hours yesterday trying to get my Android to update presence without any luck. Still unclear why it refuses to work.
@jwetzel1492 - I then found this driver and it works perfectly on my Samsung S10+. Took me 2 minutes to setup. Now you can add another Android device to the working list. Thanks!!!!
Feeling kinda stupid here.....
I've created the device driver and then created a Virtual Presence Device.
But when I click on the Virtual Presence Device I'm not seeing anywhere to enter the static IP address of my iPhone?
I don't see any field for IP address under:
Commands, Preferences or Device Info.
Did you assign the driver from the link in the first post to your virtual device?
Thank you!
I'm an idiot.
That was the problem.
You wouldn’t believe the number of times that happens to me! :wink:
