[Release] - an app for AI camera/webcam motion/object detection/recognition (motion, person, pet, vehicle, face using tinyCam)
I want to build a simple app/driver that listens for a webhook and parses it to allow switches to be set. I dont believe the specific format I have here is possible with Maker API.
Can someone please help me, point me in the right direction. Happy to attempt it myself but I've not written an app or driver before so am quite apprehensive about starting. I have started looking at the docs and videos but really need some guidance to help me save time/pain if possible.
The format of the webhook from the system I want to interface with will be something like this:
http(s)://hub_ip_address/trigger/my_event/with/key/key123456789?action=type_of_action
I want to find the various parameters ("trigger", "my_event", etc) and the "type_of_action" and then use them to set switches in HE. For example, if the "type_of_action" is such & such, then set device "trigger" to "on". But if its something else then set a different switch to "on". etc.
WIll I need an app & a driver to do this or can a driver do it?
Any existing apps/drivers I could possibly use as a template/start?
Cheers.
Can you control how the path before /trigger/my_event looks like?
If not, this can't be done directly on HE, it would need something in-between HE and your system.
Just realised I can get the webhook more like a MAKER API format, like this (in case it makes it easier)....
http(s)://hub_ip_address/apps/api/1234/device/0987/active?access_token=1234567890&activity=my_activity
Depending on "my_activity", I want to be able to throw various switches "on".
So, for example, if my_activity = "face" then turn switch "0987_face" on
Etc.
Hi Markus - pls see my update above. I can get it into the format that almost matches the standard Maker API, but with an additional parameter on the end that I need to extract and act on as illustrated above. Yeah, I can make the string anything I want, so I can put my hub's IP address in etc, no problem. I just need to be able to parse out the extra parameter off the end I think.
I can also do this...
http(s)://hub_ip_address/apps/api/1234/device/0987/active/access_token/1234567890?activity=my_activity
Yes, that should work, if the trigger are just a few well defined strings, it is rather straight forward. If you can put the rest in a format to be after the '?' then it is all easy. Easiest would be if you could put the device id after the question mark as well.
becomes:
http(s)://hub_ip_address/apps/api/1234/device/?id=0987&status=active&access_token=1234567890&
where the string "device" is the trigger above?
Not sure, but probably is possible. Can I DM you and see if we can work on this. I know you will be excited when you know what it is....
Go ahead :slight_smile:
Let me know if you need help. I've written a few apps that have webhooks (including my own version of maker api).
Your URL's for local access vs cloud will be different.
Also some good documentation here with info...
https://docs.smartthings.com/en/latest/smartapp-web-services-developers-guide/tutorial-part1.html
I don't think this can be done in a driver though... I think its limited to apps.
There's not many examples of this anywhere, so I will post what I sent over PM yesterday for those that stumble over this in the future:
definition(
    namespace: "markus-li",
    author: "Markus Liljergren (markus-li)",
    description: "None",
    category: "Convenience",
    installOnOpen: true,
    //TODO: Replace these icons???
    iconUrl:   "",
    iconX2Url: "",
    iconX3Url: "",
    documentationLink: ""
preferences {
    page(name: "pageMain", title: "Main Page", install: true, uninstall: true)
    page(name: "pageEnableAPI")
    page(name: "pageDisableAPI")
    mappings {
        path("/device/:id/:status/") {
            action: [
            GET: "getDevice"
void installed() {
    initializeAPIEndpoint()
String initializeAPIEndpoint() {
    if(!state.accessToken) {
        if(createAccessToken() != null) {
            state.endpoint = getApiServerUrl()
            state.localAPIEndpoint = getFullLocalApiServerUrl()
            state.remoteAPIEndpoint = getFullApiServerUrl()
    return state.accessToken
/* Pages */
Map pageDisableAPI() {
    dynamicPage(name: "pageDisableAPI") {
        section() {
            if (state.accessToken != null) {
                state.accessToken = null
                state.endpoint = null
                paragraph("SUCCESS: API Access Token REVOKED! Tap Done to continue")
Map pageEnableAPI() {
    dynamicPage(name: "pageEnableAPI", title: "") {
        section() {
            if(state.accessToken == null) {
            if (state.accessToken == null){
                paragraph("FAILURE: API NOT Initialized!")
            } else {
                paragraph("SUCCESS: API Initialized! Tap Done to continue")
Map pageMain() {
    dynamicPage(name: "pageMain") {
        section() {
                paragraph("API is not yet Initialized!")
                href(name: "hrefPageEnableAPI", title: "Enable API", description: "", page: "pageEnableAPI")
            } else {
                String localURL = "${state.localAPIEndpoint}/device/1234/active/?access_token=${state.accessToken}"
                String remoteURL = "${state.remoteAPIEndpoint}/device/1234/active/?access_token=${state.accessToken}"
                paragraph("LOCAL API (devices): <a href=\"$localURL\" target=\"_blank\">$localURL</a>")
                paragraph("REMOTE API: <a href=\"$remoteURL\" target=\"_blank\">$remoteURL</a>")
Map getDevice() {
    log.debug("Running getDevice() $params")
Correct. True OAUTH endpoints can only be exposed and handled by an App, not a Driver.
A driver, with the correct device network ID can handle unsolicited LAN messages on port 39501. The DNI needs to be either the MAC address, or TCPIP address (in hex), of the sender so the platform knows which device’s parse() routine to call.
This worked perfectly! Here's the log showing the parameter (just to briefly explain for anyone this is to differentiate motion types from a camera - motion, human, pet, vehicle, face)
This was the log from last night's testing of @markus's fantastic script which reported me and the missus walking around the room.
Now I have to work out how to extend it to cover everything I need. Been trying to think through the best approach. What I'd ideally like is a way to create child apps - 1 for each camera. Each child app would create a set of virtual motion sensors for that camera depending on what the users chooses as sensible for that camera (eg. lounge_cam_motion, lounge_cam_pet, lounge_cam_human. But for a driveway cam, say: driveway_cam_motion, driveway_cam_vehicle, driveway_cam_pet, driveway_cam_human). And then the motion type parameter from that specific camera would activate the relevant virtual motion sensor with an auto off after a while.
The virtual motion sensors can then be used in RM automations (send a message vehicle arrived in driveway, or turn on sprinkler when pet on lawn :smile: etc)
Changed thread title to better reflect the objective.
In case anyone else wants to try this, put your cameras into the tinyCam app. The app covers a huge range of ip/web cams (including Arlo, Wyze etc).
Once you have your cams set up, go into the camera settings for each and activate motion sensing (which happens in the app, so no special camera functionality is needed - yes you can cancel your expensive motion recognition subscriptions now :smile:). You can set up zones, adjust sensitivity etc.
You then get this panel allowing you to activate the various motion types and allowing a Webhook to be set up, near the bottom of the page (click the image to expand).
My example Webhook is shown in orange in the panel, and works with the test app that @markus put together (above in this thread). Put your own oauth token into the Webhook of course, once you've installed the app in HE.
Then open your log and see the reported motion type...
Very cool!
And thank you very much to Alex at tinyCam for responding to the request to add this additional functionality to the Webhook!
We now have a working interface with tinyCam that enables all sorts of possibilities with camera motion/object sensing across a wide range of ip/web cams!
Some tweaks to the code to:
  • allow virtual motion sensors to be selected for each motion type (motion, person, pet, vehicle face) - nb. face is non-specific/personal
  • rename the app on-save (since you need an instance for each camera - a parent/child structure would be better, but not sure yet how to do this)
  • drive the sensors to active when motion is sensed
  • added some info at the top (trust this is appropriate)
@markus graciously suggested I put my name on this (he did all the work but it was my original app idea I guess :smile: ). Since I have little clue what I'm doing, thats very kind. I've also copied some formatting from @bptworld apps and intend to try to emulate his use of parent/child structure in the future too.
   Hubitat App to allow ip/web cameras in tinyCam to drive Hubitat Virtual Motion Sensors
   tinyCam is an app available on Android/IOS/PC and can discriminate between different types of motion:
    - motion
    - person
    - pet
    - vehicle
    - face (non specific/personal)
   Set-Up:
   In tinyCam:
   - install the tinyCam Monitor Pro app (there is a free add-supported version)
   - add your cameras
   - in camera settings, motion detection, enable all the motion types
   - add a webhook http://[your_hub_ip/apps/api/XXXX/?access_token=YYYY&motion=%MOTION_TYPE%
     (where XXXX is the ID of this app once installed and YYYY is the access code reported in this app (remember to activate oath when installing)
   In Hubitat:
   - simply set-up virtual motion sensor devices (1 for each motion type)
   - then select these when you run the app
   - rename the app to be unique for your chosen camera (will move to Parent/Child format soon)
   - you can also use an html tile in a dashboard to view the live webcam (if you activate the webserver function in tinyCam)
   Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
   in compliance with the License. You may obtain a copy of the License at:
       http://www.apache.org/licenses/LICENSE-2.0
   Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
   on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
   for the specific language governing permissions and limitations under the License.
   If modifying this project, please keep the above header intact and add your comments/credits below - Thank you!
  Changes:
  0.0.2 - 20th June 2020 - Added selection of virtual motion sensors, simplified url/params, code to activate motion sensors,
                           code to rename the app [Angus Marshall]
  0.0.1 - 18th June 2020 - Initial code [Markus Liljergren]
def setVersion(){
    state.name = "tinyCam Connector"
	state.version = "0.0.2"
definition(
    name: "tinyCam Connector",
    namespace: "Angus_M",
    author: "Angus Marshall (Angus_M)",
    description: "set virtual motion sensors to active when http received from tinyCam (or other similar webcam app)",
    iconUrl:   "",
    iconX2Url: "",
    iconX3Url: "",
preferences {
    mappings {
        path("/") {
            action: [
            GET: "getDevice"
void installed() {
    log.debug "Installed with settings: ${settings}"
def updated() {
    log.debug "Updated with settings: ${settings}"
    unsubscribe()
/* Pages */
        section() {
        section() {
            } else {
Map pageMain() {
        section() {
            } else {
                String localURL = "${state.localAPIEndpoint}/?access_token=${state.accessToken}"
                String remoteURL = "${state.remoteAPIEndpoint}/?access_token=${state.accessToken}"
                input "motionDevice", "capability.motionSensor", title: "Motion: Which motion sensor to control?", multiple: false, required: true
                input "personDevice", "capability.motionSensor", title: "Person: Which motion sensor to control?", multiple: false
                input "petDevice", "capability.motionSensor", title: "Pet: Which motion sensor to control?", multiple: false
                input "vehicleDevice", "capability.motionSensor", title: "Vehicle: Which motion sensor to control?", multiple: false
                input "faceDevice", "capability.motionSensor", title: "Face: Which motion sensor to control?", multiple: false
                label title: "Enter a name for this app", required: false
Map getDevice() {
    if (params.motion == "Motion") {
        motionDevice.active()
    } else if (params.motion == "Person") {
        personDevice.active()
    } else if (params.motion == "Pet") {
        petDevice.active()
    } else if (params.motion == "Vehicle") {
        vehicleDevice.active()
    } else if (params.motion == "Face") {
        faceDevice.active()
Still to do:
  • Move to a parent/child structure
  • Create the virtual motion sensor devices automatically instead of selecting them (probably makes sense and saves the user having to do this prior to running the app)
  • Put into HPM
Enjoy!
Changed thread title to reflect "alpha" release of the app :sunglasses:
You know...this would be a good use case for MQTT. Then all those attributes could be sent....just sayin...
Interesting project, I look forward to seeing how it develops. Thanks for posting.
Making some progress with this (by heavily leveraging @bptworld's work, namely parent/child layout and nice formatting). Trust this is ok and of course noted in the code. So now a child can be created for each camera. Use the URL generated for the webhook in tinyCam with the form:
http://hub_ip/apps/api/app_number_generated_by_child_app/?access_token=your_oauth_token_generated_by_the_child_app&motion=%MOTION_TYPE%
tinyCam will put the appropriate motion type into %MOTION_TYPE% for you (eg. Motion, Person, Vehicle, Pet, Face) and the child app will identify that and activate the selected virtual motion sensor for you (to use in whatever RM rule you want).
To do still:
  • automatically create the virtual motion devices (although in a way its nicer I think to allow the user to select whichever devices they want (not all are necessarily necessary if the various AI-motion types are not all needed for a specific camera))
  • put into HPM
Parent App:
 *  ****************  tinyCam Connector  ****************
 *  Description:
 *  Manage child apps which enable webhooks from tinyCam to drive virtual motion sensors in Hubitat.
 *  Copyright 2020-> Angus Marshall (@Angus_M)
 *  Thanks to Markus (@markus) for the original code and Bryan (@bptworld) for much of the code layout and child/parent structure
 *  This App is free.  If you like and use this app, please be sure to mention it on the Hubitat forums!  Thanks.
 *  Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
 *  in compliance with the License. You may obtain a copy of the License at:
 *      http://www.apache.org/licenses/LICENSE-2.0
 *  Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
 *  on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
 *  for the specific language governing permissions and limitations under the License.
 *  If modifying this project, please keep the above header intact and add your comments/credits below - Thank you! -  @Angus_M
 *  Changes:
 *  0.0.1 - 27th June 2020 - Initial alpha release - Angus Marshall
def setVersion(){
	state.version = "0.0.1"
definition(
	author: "Angus Marshall",
	description: "Manage child apps which enable webhooks from tinyCam to drive virtual motion sensors in Hubitat.",
	iconUrl: "",
	iconX2Url: "",
	iconX3Url: "",
preferences {
     page name: "mainPage", title: "", install: true, uninstall: true
def installed() {
    initialize()
def updated() {
    unsubscribe()
    initialize()
def initialize() {
    log.info "There are ${childApps.size()} child apps"
    childApps.each {child ->
    log.info "Child app: ${child.label}"
def mainPage() {
    dynamicPage(name: "mainPage") {
    	installCheck()
		if(state.appInstalled == 'COMPLETE'){
			section("Instructions:", hideable: true, hidden: true) {
				paragraph "<b>Notes:</b>"
				paragraph "This app manages child apps, each of which can connect to a specific camera in tinyCam using the webhook generated by tinyCam."
                paragraph "Each child app will provide a url containing a unique oauth code. Put the url into the webhook for the camera, in the motion settings in tinyCam."
  			section(getFormat("header-blue", "Child Apps")) {
				app(name: "anyOpenApp", appName: "tinyCam Connector Child", namespace: "Angus_M", title: "<b>Add a new 'tinyCam Connector' child</b>", multiple: true)
			section(getFormat("header-blue", "General")) {
       			label title: "Enter a name for parent app (optional to change)", required: false
			display2()
def installCheck(){
    display()
	state.appInstalled = app.getInstallationState()
	if(state.appInstalled != 'COMPLETE'){
		section{paragraph "Please hit 'Done' to install '${app.label}' parent app "}
  	else{
    	log.info "Parent Installed OK"
def getFormat(type, myText="") {			// Modified from @Stephack Code
	if(type == "header-blue") return "<div style='color:#ffffff;font-weight: bold;background-color:#5da2c2;border: 1px solid;box-shadow: 2px 3px 5px 5px #5da2c2'>${myText}</div>"
    if(type == "line") return "<hr style='background-color:#5da2c2; height: 1px; border: 0;'>"
    if(type == "title") return "<h2 style='color:#5da2c2;font-weight: bold'>${myText}</h2>"
def display() {
    setVersion()
    getHeaderAndFooter()
    theName = app.label
    if(theName == null || theName == "") theName = "New Child App"
    section (getFormat("title", "${state.name} (${theName})")) {
        paragraph "${state.headerMessage}"
		paragraph getFormat("line")
def display2() {
	section() {
		paragraph "<div style='color:#5da2c2;text-align:center;font-size:20px;font-weight:bold'>${state.name} - ${state.version}</div>"
        paragraph "${state.footerMessage}"
def getHeaderAndFooter() {
    if(logEnable) log.debug "In getHeaderAndFooter (${state.version})"
    def params = [
		timeout: 30
    try {
        def result = null
        httpGet(params) { resp ->
            state.headerMessage = resp.data.headerMessage
            state.footerMessage = resp.data.footerMessage
        if(logEnable) log.debug "In getHeaderAndFooter - headerMessage: ${state.headerMessage}"
        if(logEnable) log.debug "In getHeaderAndFooter - footerMessage: ${state.footerMessage}"
    catch (e) {
        state.headerMessage = "<div style='color:#5da2c2'>@Angus_M Apps and Drivers</div>"
        state.footerMessage = "<div style='color:#5da2c2;text-align:center'>Angus Marshall<br><a href='https://paypal.me/angusmarshall' target='_blank'><img src='https://www.paypalobjects.com/webstatic/mktg/logo/pp_cc_mark_37x23.jpg' border='0' alt='PayPal Logo'><br>Paypal contributions welcome!</a></div>"
Child App:
   tinyCam is an Android​app that can discriminate between different types of motion:
    - motion
    - person
    - pet
    - vehicle
   Set-Up:
   In tinyCam:
   - add your cameras
   In Hubitat:
  Changes:
  0.0.3 - 27th June 2020 - Set up parent/child structure (heavily leveraging @bptworld's great work - thank you!) [Angus Marshall]
def setVersion(){
	state.version = "0.0.3"
definition(
    name: "tinyCam Connector Child",
	parent: "Angus_M:tinyCam Connector",
    iconUrl:   "",
    iconX2Url: "",
    iconX3Url: "",
preferences {
    mappings {
        path("/") {
            action: [
            GET: "getDevice"
void installed() {
	display()
def updated() {
	display()
    unsubscribe()
/* Pages */
	    display()
        section() {
	    display()
        section() {
            } else {
Map pageMain() {
        display()
        section() {
            } else {
                    paragraph("Put the following URL into the tinyCam webhook for motion on the selected camera. This app will read the webhook when transmitted by tinyCam and activate the virtual motion sensor selected below depending on the motion type (eg. simple motion, or AI-identified motion from Person, Vehicle, Pet, or (non-personal) face).")
  		        section(getFormat("header-blue", "URLs")) {
                    String localURL = "${state.localAPIEndpoint}/?access_token=${state.accessToken}&motion=%MOTION_TYPE%"
                    String remoteURL = "${state.remoteAPIEndpoint}/?access_token=${state.accessToken}&motion=%MOTION_TYPE%"
  		        section(getFormat("header-blue", "Virtual Motion Devices")) {
  		        section(getFormat("header-blue", "Child App name (optional to change)")) {
			display2()
void getDevice() {
        petDevice.active()
        faceDevice.active()
def display() {
    setVersion()
    theName = app.label
def display2() {
	section() {
    def params = [
		timeout: 30
    try {
        def result = null
    catch (e) {
Tip: I've found it best to set up the virtual motion sensors with an auto timeout - of, say, 30 seconds. tinyCam will continue to monitor for motion/objects and will retrigger every 30 seconds as needed. This means you can sit in a room, as an example use case, without moving and have the virtual motion sensor retrigger your lights as the AI finds a "person" or "face" (eg. in your rule, add the virtual motion sensor(s) to cancel auto-off lighting). It works!
(Please note I'm learning on this and by no means a coder, so proceed with caution and any feedback is very welcome :smile:)
Enjoy!
I cannot get this to work with my virtual motion devices is there a special driver that I need for the motion sensor as they are not detecting motion? I have set up the following and have install TinyCam with the webhook? do I need to install any thing else? I use the parent and child version only app?
