I see new version available to download, but when i click update, the progress bar reaches 5% and then prompts that the download failed. How can i update my hub to 2.3.2?
Try shutting down from the menu. Then remove power from the Hubitat (from the outlet end - not the microUSB end). Then restart your Hubitat and attempt the update.
Does it only take a few seconds to get to 5% or does it spend some time stuck before failing out?
@ThirdReality If it continues to fail after @aaiyar 's advice, go to network settings and change ethernet speed auto to fixed 100 and see if that helps.
