Unparseable date exception when setting date-only DateTime variable
FWIW, I'm using these variables in a different rule to check the date range and activate a scene, so I suspect/hope adding the time to them won't matter.
And in fact, adding the time to the variable got rid of the exception, as expected, and then the rule worked fine.
