Unintentional System startup with build every day?
I have unintentional “System startup with build: 2.1.8.117”. Ive talked to @bobbyD and it seems like it has something to do with my HEs Cloud Conmtroller getting stuck.
I have uninstalled Dashboard, Alexa, Sonos and a Netatmo custom app. but my HE still reboots once in a while.
I don’t think I have any other devices or apps that talks to the cloud. Does anybody know a good way to try and pin point the issue?
Can in be my Philips Bridge where IO have mostly Philips lights but also two IKEA that causes the reboots?
Hey
I have the same issue.
It started with the newest firmware update.
Hope someone know some tricks :grinning:
Have you tried loading a known good backup ?
Hubitat suspect that it’s a bad USB power supply. I replaced it for another I had at home on Friday 23:45 and since then I haven’t had any unintentional reboots.
My HE is only a week old so I don’t have any “working” backups. But as I said, looks promising after I replaced the USB power supply.
Thanks for your feedback.
I will try the same.
Will post if it still a issue.
Just an update.
Replacement of the power supply solved the problem.
:grinning:
Have a nice day.
