Unifi protect api & child - severe load
Hi,
I have complete Unifi infrastructure, circa 35 cameras and I have it integrated to my Hubitat. C8 Pro - no connectivity issues.
I have set up numerous activities like pre determined PTZ presets at certain times amongst others based on alarms etc.
I have a substantial Hubitat set up with over 400 devices and all work well, I also have integration to HA to integrate with systems not easily set up directly with HE.
My issues is the sever loading when using the UnifiProtectAPI - although everything works fine and I believe all my Unifi protect firmwares are up to date, and my hubitat drivers according to HPM, UnifiProtectAPI and child devices UnifiProtectChild-PTZCamera are all up to date. in fact almost all unififi protect devices are causing a warning and severe loading.
when I disable the UnifiProtectAPI the severe laod dissapears.
Below is a snapshot of some of the warnings and was hoping someone may have an idea of where I try next.
thansk in advance.
Nick.
2709
2026-04-28 07:31:39.205 AM
error
com.hubitat.app.exception.LimitExceededException: Device 2709 generates excessive hub load on line 3241 (method ReceiveData)
dev:2709
2026-04-28 07:31:17.393 AM
error
com.hubitat.app.exception.LimitExceededException: Device 2709 generates excessive hub load on line 3241 (method updated)
dev:2709
2026-04-28 07:31:16.433 AM
error
dev:2709
2026-04-28 07:31:16.375 AM
error
dev:2709
2026-04-28 07:31:01.212 AM
error
dev:2709
2026-04-28 07:31:00.987 AM
error
dev:2709
2026-04-28 07:30:53.719 AM
error
dev:2709
2026-04-28 07:30:46.103 AM
error
dev:2709
2026-04-28 07:30:45.973 AM
error
dev:2709
2026-04-28 07:30:30.994 AM
error
dev:2709
2026-04-28 07:30:30.909 AM
error
dev:2717
2026-04-28 07:30:30.108 AM
error
com.hubitat.app.exception.LimitExceededException: Device 2709 generates excessive hub load on line 428 (method ProcessEvent)
dev:2717
2026-04-28 07:30:29.598 AM
error
dev:2717
2026-04-28 07:30:28.990 AM
error
dev:2717
2026-04-28 07:30:28.958 AM
error
dev:2775
2026-04-28 07:30:26.075 AM
error
dev:2775
2026-04-28 07:30:26.043 AM
error
dev:2775
2026-04-28 07:30:25.519 AM
error
dev:2775
2026-04-28 07:30:25.082 AM
error
dev:2775
2026-04-28 07:30:23.148 AM
error
dev:2775
2026-04-28 07:30:23.116 AM
error
dev:2775
2026-04-28 07:30:20.075 AM
error
dev:2775
2026-04-28 07:30:19.996 AM
error
dev:2775
2026-04-28 07:30:19.945 AM
error
dev:2717
2026-04-28 07:30:18.097 AM
error
dev:2717
2026-04-28 07:30:18.041 AM
error
dev:2717
2026-04-28 07:30:17.982 AM
error
dev:2709
2026-04-28 07:30:16.030 AM
error
dev:2709
2026-04-28 07:30:15.878 AM
error
dev:2709
2026-04-28 07:30:15.870 AM
error
dev:2709
2026-04-28 07:30:14.517 AM
error
dev:2709
2026-04-28 07:30:13.380 AM
error
PROTECT PTZ CONTROL - Login error with no status information - Likely due to MFA, please confirm Login without MFA method
dev:2717
2026-04-28 07:30:12.710 AM
error
dev:2717
2026-04-28 07:30:12.661 AM
error
dev:2717
2026-04-28 07:30:12.117 AM
error
dev:2717
2026-04-28 07:30:11.619 AM
error
dev:2775
2026-04-28 07:30:10.958 AM
error
dev:2775
2026-04-28 07:30:10.893 AM
error
dev:2775
2026-04-28 07:30:10.361 AM
error
dev:2775
2026-04-28 07:30:09.811 AM
error
dev:2709
2026-04-28 07:30:01.862 AM
error
dev:2709
2026-04-28 07:30:01.537 AM
error
dev:2709
2026-04-28 07:30:01.535 AM
error
dev:2730
2026-04-28 07:29:59.257 AM
error
com.hubitat.app.exception.LimitExceededException: Device 2709 generates excessive hub load on line 388 (method ProcessEvent)
dev:2730
2026-04-28 07:29:59.214 AM
error
dev:2730
2026-04-28 07:29:59.203 AM
error
dev:2730
2026-04-28 07:29:59.158 AM
error
dev:2730
2026-04-28 07:29:51.346 AM
error
dev:2730
2026-04-28 07:29:51.300 AM
error
dev:2730
2026-04-28 07:29:51.288 AM
error
dev:2730
2026-04-28 07:28:59.219 AM
error
dev:2730
2026-04-28 07:28:59.175 AM
error
dev:2730
2026-04-28 07:28:59.130 AM
error
dev:2709
2026-04-28 07:28:47.524 AM
error
dev:2724
2026-04-28 07:28:44.746 AM
error
dev:2724
2026-04-28 07:28:44.715 AM
error
dev:2724
2026-04-28 07:28:44.687 AM
error
dev:2803
2026-04-28 07:28:43.142 AM
error
com.hubitat.app.exception.LimitExceededException: Device 2709 generates excessive hub load on line 420 (method ProcessEvent)
dev:2730
2026-04-28 07:28:42.298 AM
error
dev:2730
2026-04-28 07:28:41.586 AM
error
dev:2730
2026-04-28 07:28:40.791 AM
error
dev:2730
2026-04-28 07:28:40.744 AM
error
dev:2730
2026-04-28 07:28:35.818 AM
error
dev:2730
2026-04-28 07:28:35.773 AM
error
dev:2803
2026-04-28 07:28:34.910 AM
error
dev:2745
2026-04-28 07:28:34.485 AM
error
com.hubitat.app.exception.LimitExceededException: Device 2709 generates excessive hub load on line 241 (method ProcessEvent)
dev:2730
2026-04-28 07:28:33.901 AM
error
dev:2730
2026-04-28 07:28:33.856 AM
error
dev:2730
2026-04-28 07:28:33.388 AM
error
dev:2730
2026-04-28 07:28:32.988 AM
error
dev:2803
2026-04-28 07:28:32.307 AM
error
dev:2803
2026-04-28 07:28:31.782 AM
error
dev:2745
2026-04-28 07:28:31.255 AM
error
dev:2730
2026-04-28 07:28:30.158 AM
error
dev:2730
2026-04-28 07:28:30.109 AM
error
dev:2730
2026-04-28 07:28:30.096 AM
error
dev:2803
2026-04-28 07:28:26.992 AM
error
dev:2730
2026-04-28 07:28:26.250 AM
error
dev:2730
2026-04-28 07:28:25.784 AM
error
Which UniFi Protect integration are you using? The Hubitat provided built-in integration? Or one of the community integrations? Sounds like a community integration since you mentioned HPM.
If the latter, you’ll get better support by posting in that developer’s existing forum thread.
Yes, @user309 reached out to me in a message (I assume based on your recommendation @ogiewon, so thanks!). I saw this also after a recent Hubitat update (no driver changes in the version before, and no changes afterward before the errors started). Was driving me crazy because it all traced back to the standard Hubitat sendEvent line (which is part of code I have not changed in a long time...) until I rebooted the hub fully (not just the reboot as part of the update) and the problem went away.
Mine has been running since without any of these errors again. Not sure WHY it started and the logs told me just about nothing... but since a reboot solved it, that is what I recommended. Hopefully they will come back with it being solved.
