Unexpected behavior with "No Selection" for app input
I have an app input setting called myValue with a type enum. If I choose the option "No selection" then myValue is no longer listed in the settings, totally disappears.
I find this a bit odd. I expected it to be null or perhaps a zero length string but to have it disappear altogether seems wierd given I've taken the trouble to define it and give it a default value.
Is there a way to remove this option? It's presence only adds to the error checking that must occur and is likely to produce an unintended outcome?
The defaultValue option applies only to the default selection in the interface the first time the app page is loaded, but it does not write a value to settings on its own (not until the user saves the app with that selection). If the input is not required, then your code should be written to handle a null or no value for that particular setting (though really it's a good idea to handle this gracefully regardless--it could still happen).
To address your particular question, it sounds like required: true might do what you want. For other ways to handle this, you could specify some default value in your app code to use in case there is no user-supplied (or otherwise stored) value (e.g., perhaps pulling it from a static field variable you defined for this purpose, among other options).
