Unable to update my C7 past Platform version: 2.3.4.119
Diagnostics tool version: 1.0.97
I have tried updating from the regular UI and it just sits on the checking for update screen forever. I went into the diagnostic tool and synched the time with my browser, then rebooted the hub. It still won't find an update file. I also tried using the diag tool to perform the update but when I try that I get an error saying "Could not fetch latest version information." So it seems both the regular update and the diag tool are unable to get the latest version of code. I'm not doing anything goofy or weird on my network at the moment. The only "odd" thing is that my firewall doesn't support uPNP. I did have a SSL certificate loaded on the hub which was worked except it prevented me from getting to the network settings page on the hub. I've disabled HTTPS and now I can get to the network page but I still can't successfully update the hub.
Also, the app on my android can't find the hub on the local network but I can log into the web interface from my computer just fine.
Never mind, I figured out the problem was that the hub wasn't working properly with the static IP. For whatever reason, DNS was failing. I switched it to DHCP and it started working again.
I suggest keeping it that way and setting a reserved IP for the hub in the DHCP settings on the router.
