Unable to pair second Linkind contact sensor
Attempting to pair a second Linkind sensor to hub. When I start the pairing process the hub finds my existing sensor but not the one I'm trying to add. Any suggestions? Thanks.
dumb question but if you click on the linkind sensor's device page that's already installed but open and close the new one, is that reflected on the other sensor's attributes?
No
So I tried removing the battery from the existing sensor and then pairing the new one. Still no luck. Now I"m wondering if I remove the first sensor from the network and then try to pair the new one as well as add the first on back. Would that work?
Can't hurt to try. It's weird though because for it to say it's existing means it would have had to initially have it paired. I've never seen a pairing say it was a different device.
Well I redid them both and they both paired. I think you're right that I had previously paired the second sensor. It was just long ago enough that I had forgotten. Thanks for your help.
