Unable to enable OAuth for App Code on C8 Pro Hub
I am in the process of setting up a new C8 Pro hub environment and have imported two user apps from Konnected. One of these apps requires OAuth to be enabled. To enable OAuth, I open the user app, toggle the OAuth option, and save the changes. However, when I check the list of apps afterward, the OAuth setting does not appear as enabled for that app.
Interestingly, I have not encountered this issue with the same installation on my C7 hub environment. I am unsure whether this issue is related to Hubitat or Konnected. Unless I am missing some other steps to enable OAuth on my C8 Pro hub?
i think this is a reported bug in the new ui.. i assume will be fixed soon.
@gopher.ny
@kahn-hubitat Thanks for your fast response, indeed Hubitat team just released 2.4.0.146 which fixed the OAuth user app issue.
