Trying to control an IKEA outlet using SamSung Smarthing button. Both are discovered without a problem. I can control the IKEA outlet from the web interface. I can go into logs and verify the 3 different button presses of the Samsung Button. When I try to connect the Samsung button to the IKEA Outlet using the Button Controller app I get the following output in logs -
dev:1702019-02-16 03:07:20.983 pm debugdescMap: [raw:catchall: 0104 0006 01 01 0040 00 7EAF 00 00 0000 0B 01 0000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:7EAF, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:1702019-02-16 03:07:20.981 pm debugparse: catchall: 0104 0006 01 01 0040 00 7EAF 00 00 0000 0B 01 0000
dev:1732019-02-16 03:07:20.828 pm infoSamsung Button 2 button 1 was pushed
dev:1732019-02-16 03:07:20.826 pm debugparse: zone status 0x0001 -- extended status 0x00
I have tried deleting the button controller and the button app and recreating with the same result.
Suggestions ?
