Unable to connect to hub
I have C7 hub connected to my router by wire. Today I noticed that I am not able to connect to it via browser. I THINK the android app is still able to see it because when I start the app, and click on dashboard it does load all tiles. The app also shows the IP address. I see that the hub has green light on. I have not been using the hub for few months now so just coming back to it after quote some time.
Out of despair, I'll confess that I did pull out it's power cable and reinstated the wire(I know I should ideally not have done this), but the hub did reboot I think as it has green light right now.
When I navigate to the ip address on browser, I get ERR too many retries error. What can I try to access the web UI again?
Could try : https://my.hubitat.com
Then try : find Hubs < to get ip ..
Or Lokk on your router to see if it has a IP
Or Use: https://www.advanced-ip-scanner.com < scan your system to find IP
Or : https://angryip.org
From the app, I see that the dashboard is working and I can even toggle a smart plug on and off. So it's just the website UX not loading for some reason. I am out of home right now. Will try your suggestions soon.
I tried this now. My.hubitat.com showed me the same 192.168.168.x ip which I was trying. I was again able to open dashboard, but the direct IP, instead of opening the web page, gave me below error:
http://192.168.88.x might be temporarily down or it may have moved permanently to a new web address.
ERR_TOO_MANY_RETRIES
Try : http://192.168.50.X:8081
then try : reboot hub
I had this on Chrome on my Pixel phone the other day. I fixed it with: https://community.hubitat.com/t/2-5-3-108-cannot-get-to-hub-from-chrome-on-android-phone-pixel-8-pro/167107/11?u=jlv
This is what it says, In case you aren't in the beta forum:
Or for those not in the Beta group...
Ok! So I just discovered that chrome on my android phone is where I am getting this error.. But was able to open the hub page on my laptop! I'll check out your link
That was it!! Thanks.
I think this is breaking UX issue and a lot of users perhaps might frantically try Extreme steps, such as I pulling plug on my hub.
Except as best as I can tell it was something that changed in Chrome and not on the hub.
