I am having trouble setting up multiple z-wave devices. I can add one device and it works well. Then I add a second device of the same type and the first device disappears from the list of devices. I see the DNI number is the same for both devices.
This behavior occurs on both Aeotec range extenders and Inovelli Red dimmer switches.
Here is the log after the second device is added
dev: 1 2021-10-14 02:20:42.730 pm warn installed...
sys:1 2021-10-14 02:20:28.749 pm Z-Wave Discovery Running
sys:1 2021-10-14 02:17:28.465 pm Error at point 184a6b Expired JWT
I have done multiple things to try to resolve this including excluding and factory resetting all z-wave devices, shutdown the hub, reboot the hub, Repair Z-wave, Reset z-Wave Radio, Soft reset, and finally a factory reset.
Hardware version c-7
Platform version 2.2.9.130
