Ultraloc Zwave - can you still connect it without their app?
Can you still connect the Ultraloc to Hubitat without using the Ultraloc App, as described by @mbbush in this post:
or has Ultraloc somehow closed that back door?
I need to replace a non-connected keypad lock on a crawlspace door, and am looking for one with physical keys that is rated for punishing sun, has a keyed backup, smaller form factor and can be connected to HE. Despite it's drawbacks noted on numerous posts, the Ultraloc seems to meet those criteria. I don't care about knowing which code was used to open it, because I'll give it it's own code, and I'm the only one who ever uses its. However, if it needs their app to work, I'm not buying it...
I cannot imagine it would pass zwave certification with SmartStart if you had to use the vendors app. Maybe just make sure you can pair it up before installing it. In case you need to send it back.
Thanks!
That is the same post I was attempting to link to - LOL. I edited to link ot post 26 instead of the incorrect 25 in that thread...
