UG C5 to 2.3.6.134 blue light
Upgraded from 2.3.5.152 to 2.3.6.134
all seemed to go well, no errors reported. 15 minutes later is still says hub is rebooting and the LED is blue.
Is port 8081 available? If so, can you switch back and PM me the hub id? I'll check the engineering logs for errors.
8081 did not respond. However a reboot of my router has everything up and running again. Same IP address, but something was amiss. Anyway thanks for the reply gopher -
