I agree with @rlithgow. Configure a DHCP reservation in your router’s settings page, and keep your Hubitat hub in its default DHCP mode (or push that button on the bottom to reset back to DHCP).
Dont set a static IP address on the hub’s network settings page unless you’re absolutely sure you know what you’re doing.
This post from a while back might help explain the difference between the two terms DHCP reservation and static IP address assignment.
