Two instances of one Kasa device
I have several Kasa plugs that all work correctly but I have one device that shows up twice in Hubitat (both instances shows up as Living Room Standing Lamp). I have removed both instances of the device from Hubitat and removed it from the Kasa app on my phone. I then re-added the device to Kasa and called it Standing Lamp but when I scan for new devices in the Hubitat integration, I still get two devices called Living Room Standing Lamp. Is there a way to clear the cache or whatever and get a fresh scan so the device only shows up once and with the updated name?
Thanks!
Chris
Simple solution is to install both, find out which one actually controls the lamp, then delete the other one. Otherwise, some significant investigation.
They both control the lamp. It's really weird. I did notice that when I go through the process of adding the device to the Kasa integration, when they're both displayed, one says it's a cloud integration but that's the only screen where it says that. And why isn't the new, updated name showing up?
delete the one that is cloud. Otherwise, a lot of time for little value added.
