great i knew you were the guy
yes rgbw
so color and cold to hot white
i will check for your post about this driver
Try this new driver - should add color ... and many other things, that I don't fully understand yet.
First click on 'Save Preferences' (don't change any default values). Then click on Configure.
Hello kossev work great for me thanks
What I have noticed with my bulb (its a different model than yours) is that when changing the bulb color, the level jumps always to 100% .
Also, when in color mode, the brightness isn't great .. : (
Brightness isbnot fantastic too
For thé coloré change it dépends if brightness isbtoi low it juste shut off when i change coloré otherwise it act normaly
BTW, when I deleted and then paired my Tuya bulb as a new device before 2 days, surprisingly it was detected correctly edpointId:01, the right manufacturer and model ... Is it possible that the latest HE platform update has fixed the F2 bug?
Just to let you know this driver ( by kkossev new driver ) works great with two types of zigbee bulbs I have, both of which are supposed to be Tuya but I am not sure. Tha package labelling is terrible. One is simply called Smart Bulb and the other Sparkle Zigbee Smart Bulb. Bother made in China and bought on ebay from local Australian sellers.
Hi, Kkkshsev.
I'd like to know the possibility of add the Do-not-disturb feature, to prevent lamps turning on during power outages.
Do-not-disturb works like Power-on restore, but for some reason, Power-on restore doesn't work with my GU10 Moes lamps or my Zemismart LED Strip.
This is the fingerprint from one of my GU10 from Moes:
fingerprint profileId:"0104", endpointId:"01", inClusters:"0003,0004,0005,0006,1000,0008,0300,EF00,0000", outClusters:"0019,000A", model:"TS0505B", manufacturer:"_TZ3210_rcggc0ys"
And this is the fingerprint from one of my Zemismart LED Strip (one color):
inClusters:"0003,0004,0005,0006,1000,0008,0300,EF00,0000", outClusters:"0019,000A", model:"TS0501B", manufacturer:"_TZ3210_4zinq6io"
Zemismart LED Strip with colors:
fingerprint profileId:"0104", endpointId:"01", inClusters:"0003,0004,0005,0006,1000,0008,0300,EF00,0000", outClusters:"0019,000A", model:"TS0505B", manufacturer:"_TZ3210_3lbtuxgp"
The Do-not-disturb works perfectly well on Zigbee2MQTT, so I think it's completely possible work with Hubitat too, but the driver needs it.
There are some Threads on GitHub, but I think it may help: Power On Behaviour Packet Sniff - TS0505B / _TZB210_tmi0rihb "Zigbee 3.0 5 in 1 LED Strip Controller Model LM052" · Issue #16325 · Koenkk/zigbee2mqtt · GitHub
'Tuya Advanced Zigbee RGBW Bulb' version '1.1.0 '2023/03/20 10:35 PM' now has the DND mode for these Tuya bulbs, that support it (not all models do!)
Thanks to Vitor for the tests!
Great news! Thanks, Kkossev!
