Tuya shade, blind, curtain controller
I have just installed external shades using the ShawSmart system and motors with both RF and Zigbee control. I'm told they are part of the Tuya ecosystem, When the pair they come up at Moes 1/2/3 gang switches with 4 childs. But as you can guess this does work. I have tried each of the inbuilt drivers, but no luck.
Has anyone managed to get these to work? could it pair into one of the other Tuya custom drivers?
Details:
Manufacturer: _TZE200_2odrmqwq
Endpoint 01 application: 48
Endpoint 01 endpointId: 01
Endpoint 01 idAsInt: 1
Endpoint 01 inClusters: 0000,0004,0005,EF00
Endpoint 01 initialized: true
Endpoint 01 manufacturer: _TZE200_2odrmqwq
Endpoint 01 model: TS0601
Endpoint 01 outClusters: 0019,000A
Endpoint 01 profileId: 0104
Endpoint 01 stage: 4
Zigbee2MQTT has driver code for it, not sure if this could be used....
Any help appreciated.
C
Hi C,
This device should be working with the community driver :
Its fingerprint is not in the code yet, I will add it when I have a chance. Let us know whether it works with the default settings in the driver, or you will need to modify some of the preferences.
Hi Krassimir,
That worked, thank you!
I added:
fingerprint profileId:'0104', endpointId:'01', inClusters:'0000,0004,0005,EF00', outClusters:'0019,000A', model:'TS0601', manufacturer:'_TZE200_2odrmqwq' ,deviceJoinName: 'Tuya Zigbee Roller Blinds Motor' // Added by Callumgw
I had searched for Tuya blind controller, but didnt find the Zemismart, hopefully this now closes the loop.
Thanks again
C
