I have one of these and I've been users the 'in-built' Advanced Zigbee RGBW Bulb driver. For the most part it works OK but it is a bit erratic in that it does not always turn on or it will turn on and then off immediately.
I've had a search but cannot find any reference to this device.
Any one else have this and have it working OK.
@kkossev, as the Tuya guru, creep creep, can this be integrated into one of your drivers or could you suggest a driver to try.
Here's the device info.
Thanks.
You need to be logged in to GitHub.com , then type backslash '/' and search for the manufacturer Id :
This device has 6 references on GitHub, revealing similar problems...
The easiest solution is to bring it to Hubitat via a Tuya Matter gateway hub.
... or ...
Thanks for the reply.
It was a cheap and cheerful strip. It is failing in a couple of places so doesn't show all the colours available. As I use it for red only it works ok.
It's 20m in length so replacing it with something more conventional will cost a bit.
That's the trouble with buying cheap devices.
I'll have to have a think.
Thanks again for the reply.
