My Moes/Tuya dimmer will not go ON by the built in Scenes app. The dimmer goes off but will not go on. Has anyone else run into this issue?
Quite frankly, I would toss this thing in the garbage if I could find a non-Tuya dimmer module.
details:
Moes Dimmer module model: MS-105z.
I am using the "Tuya Zigbee dimmer module" driver ver 0.7.0 2024/06/02 kkossev
The dimmer reports:
- inClusters: 0000,0004,0005,EF00
- manufacturer: _TZE200_la2c2uo9
- model: TS0601
The logs captured during Scene "activation" is
dev:40772024-08-13 23:55:26.731infoMoesTestScene indicator off
dev:40372024-08-13 23:55:26.547infoAccent (Moes) Dimmer Accent (Moes) Dimmer level was set to 49 [digital]
dev:40372024-08-13 23:55:26.542infoAccent (Moes) Dimmer Brightness 01 is 49% (49)
dev:40372024-08-13 23:55:26.537debugAccent (Moes) Dimmer parseTuyaCluster: received: Tuya brighntness(level) cmd=02 value=490
dev:40372024-08-13 23:55:26.534debugAccent (Moes) Dimmer parse: received raw description: catchall: 0104 EF00 01 01 0040 00 62F4 01 00 0000 02 01 007B02020004000001EA
dev:40372024-08-13 23:55:26.485debugAccent (Moes) Dimmer parse: catchall received confirmation from clusterId=EF00 for command=0B data=[00, 00]
dev:40372024-08-13 23:55:26.480debugAccent (Moes) Dimmer parse: received raw description: catchall: 0104 EF00 01 01 0040 00 62F4 00 00 0000 0B 01 0000
dev:40372024-08-13 23:55:26.430debugAccent (Moes) Dimmer sendZigbeeCommands: [he cmd 0x62F4 0x01 0xEF00 0x00 {3D3C02020004000001EA} {}, delay 2000]
dev:40372024-08-13 23:55:26.427debugAccent (Moes) Dimmer cmdSetLevel: TS0601: sending cmdsTuya=[he cmd 0x62F4 0x01 0xEF00 0x00 {3D3C02020004000001EA} {}, delay 2000]
dev:40372024-08-13 23:55:26.424debugAccent (Moes) Dimmer Accent (Moes) Dimmer sendTuyaCommand = [he cmd 0x62F4 0x01 0xEF00 0x00 {3D3C02020004000001EA} {}, delay 2000]
dev:40372024-08-13 23:55:26.419debugAccent (Moes) Dimmer cmdSetLevel: TS0601: sending cmdSetLevel command=02 value=490 (000001EA)
dev:40772024-08-13 23:55:26.370infoMoesTestScene indicator on
