I've set up an automation in Hubitat to control my WiFi tuya vacuum and it works but I've run into a problem. The motion sensors in Hubitat are set to trigger an outlet that is in Google Home to trigger the vacuum (via a tap-to-run) to clean for 10 minutes, if there's been no motion detected for 25 minutes. I've tested the actions in the automation and everything works...
The problem is the vacuum won't stay in standby, it just turns itself off and I can't see any way to keep it awake?
Any one have any suggestions? This working would be really useful given my worsening mobility.
