Good Day.
I've managed to set a few rules and triggers up in rule machine but couldn't figure this one.
I would like to turn a light on for a duration ( say 5 mins) after a door is opened. Then have the light go off. Was fairly simple in IRIS but i stumbled through trying this today and couldn't quite get it right.
IRIS door contact sensor V1
Wave Light Switch
Thats as a minimum what im trying to accomplish.
there is a variation if it will work.
Same rule as above, but stay on if there its motion - then go off x mins after motion stops.
I don't have the motion sensor yet...well i did but i don't think the IRIS gen 1 motion sensors work yet.
There is the scenario ( if it helps understand what im trying to accomplish)
I have a garage door on the outside of my home and a garage door between the house and garage. The only place to control the light is by the garage door between the garage and house, so when i leave for work in the dark, i either leave the light on, or walk out through the garage in the dark ( trip hazard). I had a rule in Iris where the Garage door light would stay on for 2 or 3 minutes when the garage door contact sensor was opened.
So as a minimum - i'd like to get back to that state.
The only drawback was if i went out into the garage in the evening and was out there for a few minutes, the light would shut off on its own ( based on the rule) so given the option i'd like to incorporate a motion sensor to the rule.
- Lights on when contact sensor open ( makes it rather immediate)
- Stay on for a minimum of 2 mins
- remain on if there is motion
- shut down 1 min after motion stops.
Appreciate if anyone can point me in the right direction.
Mac
