I am converting from insteon to Hubitat. Insteon has some great functionality that I am trying to duplicate with Hubitat using a Zooz ZEN32 Scene Controller and ZEN72/77 dimmers.
I want to create a rule that uses a button to turn on a set of dimmers to a light level. Then I want the rule to use that same button to increase the light when held and released or turn off the lights when the same button is double tapped.
I was able to create a rule that turns on the lights, then will increase the light level when held and released. Then only after I hold and release will it turn the lights off with a double tap of the same button. The problem is I can go directly from turning on the lights with a button press to turning off the lights with a double tap if I do not want to increase the light level before turning off the lights.
