Decided to finally hook up my C7 and at least make sure it can talk . I had planned to use the new migrating service but that is taking a while so I figured I better at least make sure it works.
The scan showed all three of my hubs. My two currently running hubs and a new one called my new hub. When I would click on the hub to configure it, it would refuse the connection and time out. I have a Netgear Nighthawk R6700 router and I run the built in VPN. When looking in the router table the new hub was showing up in my VPN IP list.
I realized when I setup up my first two hubs I had not setup the VPN yet. So I turned off the router VPN and then the new hub connected and I was able to get it setup on the network. After setup I turned the VPN back on and everything is working great. Anyone know why?
