@jjackson can you take a look at this rule something must be wrong because I am not getting the delay 1 minute. It says the announcement every time the motion sensor is active and does not delay 1 minute.
yes - The reason it is not working is your opening statement looks for PB False - change to True. If it is true then exit. Statement 4 turns PB True - correct. Now insert a statement to become the first line to turn PB false, delay 1 min. If this is the first statement then it will keep things in sync.
forgot to say to delete the last statement - set PB True delay 1 min - you already set to true in line 4.
Set PB False delay 1 min
IF PB true, exit
Set PB true
Your Homeseer IF statement
BTW - this is the perfect example of an app that needs throttling. Motion triggered as a whole I tend to use throttling for just what you describe - only let the first trigger through, then lock the door for one minute. You got it. jj
Thank you @jjackson for your help, everything seems to be working good now with the 1 minute delay. I will convert over all my outside motion rules with this tuning process. Here is my final config.
Dead on!
Congrats - go pull a copy of your application and device load in logs, reset and check tomorrow and see if the throttle is helping lower CPU time. It will. Well done jj
Another use case here, motion triggers the Hikvision and Dahua PTZ cameras to turn around and look at the area for a period of time and not get over spammed by the motion sensor.
That is a great one! jj
The HE guys did an outstanding job adding the CPU load for apps and devices to the log! One heck of a good resource to spot apps that can benefit from throttling. Just FYI - Zwave RGB bulbs are a PITA; 30% of the CPU time for 100+ devices is spent on 3 RGB zwave bulbs. HUE arrives today, 3 zwave RGBs are getting the exclude button by nightfall, I always knew they sucked from looking at the packet sniffer and just hordes of packets with unknown command errors. Throwing in this case is the solution not throttling. . jj
