TS - ECO Mode
I am using the thermostat scheduler app in conjunction with a honeywell Z-wave stat. When using ECO mode is there a way to have an indication of ECO mode on/off on a dashboard? I don't see a way to make this happen.
Disclaimer: I don't have one of these exact stats, so I am taking an educated guess here.
You might look and see if the "Attribute" tile has anything you can use. I suspect one of these may work.
I tried this route. The attributes are tied to the stat only. The stat itself does not have an ECO mode. The ECO mode looks like it resides in the app only (scheduler). If the scheduler app showed as a device (or had a child that did) then I believe it could be presented into dashboards, but I'm no coding expert :laughing:.
Ah, thanks for the clarification. I thought it was the thermostat that had the eco mode.
