Hi. On the Network setup page, it has a status circle continuously running and says working on it by the install wifi drivers. It never goes away. I think it must have got hung up trying to install wifi drivers and now it's stuck. I've rebooted several times. Is there a way to reset it without losing programming?
I'm trying to set up the hub for Wifi.
Are you using the properly compatiple wifi dongle?
Could try:
Also, can you try updating to the latest 2.3.4.130 firmware? The networking page was redone recently.
Probably not. It is a Netgear R-NZ. I had it sitting unused and thought I might get lucky and it would accept it.
ok thanks. I will give that a try.
Not compatible. There’s a select number of TP-Link dongles that are compatible.
ok. I will locate one and try again. Thank You.
