I've been trying to follow this guide here:
Seems straight forward, but when I run the docker, it immediately stops with the error in the logs: standard_init_linux.go:211: exec user process caused "exec format error"
I'm pretty new with docker and rasp pi stuff. I have a raspberry pi4 and running raspbian buster.
When I get to step 5 of the guide, the file's not found/empty because the docker fails to start... Any guidance here?
I really think this question is more appropriate for the Home Assistant forums, as the parts you are stuck on are 100% Home Assistant...
That said I'm sure some nice soul with more time than I will help anyway.
Also, I believe that post was done by our resident @jeubanks who can probably assist via PM. As Jason mentioned, it's probably best discussed in the HA forum but @jeubanks is a resident there as well.
Thanks guys - I found all the previous guides and questions from our forums here at hubitat so I asked here ignorantly - I apologize. I reached out to @jeubanks in a PM too... thanks again!
No worries, and no apologies needed. I just want to make sure you get the right help to move forward. If you haven't made progress by this weekend I'll try to take a look.
I've had MQTT setup in my HA docker for long enough now I don't remember the exact steps I used - so can't do it from memory. The way I did it was very easy though, I do remember that.
I haven't even touched that integration in over a year!! I'm not sure if it would even work today or not.
Are you no longer using both products then? Or do you use some other method to tie the two (HE and Hass.io) together?
I've been away... My home env is mostly Insteon with some Z-Wave and Zigbee. I use the ISY for Insteon and some Z-Wave and then Hubitat for the ZigBee integration. I also developed a Hubitat -> ISY integration that I now use and I then layer HASS to the ISY which provides a nice UI. There is currently some issues with the nodeserver devices (Hubitat integration) not showing as well as I would like in the HASS UI but it's a work in progress.
Obviously the easiest to do a HE -> HASS would be direct MQTT which if I remember correctly someone else was working on...
Yes paging @kevin
I have home assistant connected with HE through his app
