This is from the S2 contact sensor.
dev:2722026-10-27 6:33:41.616 pm
debug
parsed '{"cc":113,"cmd":5,"ep":0,"values":[{"ccVersion":8,"newValue":0,"endpoint":0,"metadata":{"readable":true,"min":0,"max":255,"label":"Alarm Type","secret":false,"writeable":false,"type":"number","stateful":true},"propertyName":"alarmType","commandClass":113,"property":"alarmType","commandClassName":"Notification","value":0,"prevValue":0,"ts":1793144021576},{"ccVersion":8,"newValue":0,"endpoint":0,"metadata":{"readable":true,"min":0,"max":255,"label":"Alarm Level","secret":false,"writeable":false,"type":"number","stateful":true},"propertyName":"alarmLevel","commandClass":113,"property":"alarmLevel","commandClassName":"Notification","value":0,"prevValue":0,"ts":1793144021577},{"ccVersion":8,"propertyKey":"Opening state","newValue":0,"metadata":{"readable":true,"min":0,"ccSpecific":{"notificationType":6},"max":255,"label":"Opening state","secret":false,"writeable":false,"type":"number","stateful":true,"states":{"0":"Closed","1":"Open"}},"commandClass":113,"prevValue":1,"propertyKeyName":"Opening state","endpoint":0,"propertyName":"Access Control","property":"Access Control","commandClassName":"Notification","value":0,"ts":1793144021583}]}' to [[name:contact, value:closed, descriptionText:Garage Door Sensor was closed]]
dev:2722026-10-27 6:33:41.612 pm
debug
parsed '{"cc":113,"cmd":5,"ep":0,"values":[{"ccVersion":8,"newValue":0,"endpoint":0,"metadata":{"readable":true,"min":0,"max":255,"label":"Alarm Type","secret":false,"writeable":false,"type":"number","stateful":true},"propertyName":"alarmType","commandClass":113,"property":"alarmType","commandClassName":"Notification","value":0,"prevValue":0,"ts":1793144021576},{"ccVersion":8,"newValue":0,"endpoint":0,"metadata":{"readable":true,"min":0,"max":255,"label":"Alarm Level","secret":false,"writeable":false,"type":"number","stateful":true},"propertyName":"alarmLevel","commandClass":113,"property":"alarmLevel","commandClassName":"Notification","value":0,"prevValue":0,"ts":1793144021577},{"ccVersion":8,"propertyKey":"Door state","newValue":23,"metadata":{"readable":true,"min":0,"ccSpecific":{"notificationType":6},"max":255,"label":"Door state","secret":false,"writeable":false,"type":"number","stateful":true,"states":{"22":"Window/door is open","23":"Window/door is closed","5632":"Window/door is open in regular position","5633":"Window/door is open in tilt position"}},"commandClass":113,"prevValue":22,"propertyKeyName":"Door state","endpoint":0,"propertyName":"Access Control","property":"Access Control","commandClassName":"Notification","value":23,"ts":1793144021584}]}' to [[name:contact, value:closed, descriptionText:Garage Door Sensor was closed]]
dev:2722026-10-27 6:33:41.614 pm
info
dev:2722026-10-27 6:33:41.611 pm
debug
NotificationReport cmd:NotificationReport(v1AlarmType: 0, v1AlarmLevel: 0, notificationStatus: 255, notificationType: 6, event: 23, sequence: false, eventParametersLength: 0, eventParameter: [], sequenceNumber: 0)
info
dev:2722026-10-27 6:33:41.608 pm
debug
dev:2722026-10-27 6:33:10.596 pm
debug
parsed '{"cc":113,"cmd":5,"ep":0,"values":[{"ccVersion":8,"newValue":0,"endpoint":0,"metadata":{"readable":true,"min":0,"max":255,"label":"Alarm Type","secret":false,"writeable":false,"type":"number","stateful":true},"propertyName":"alarmType","commandClass":113,"property":"alarmType","commandClassName":"Notification","value":0,"prevValue":0,"ts":1793143990532},{"ccVersion":8,"newValue":0,"endpoint":0,"metadata":{"readable":true,"min":0,"max":255,"label":"Alarm Level","secret":false,"writeable":false,"type":"number","stateful":true},"propertyName":"alarmLevel","commandClass":113,"property":"alarmLevel","commandClassName":"Notification","value":0,"prevValue":0,"ts":1793143990540},{"ccVersion":8,"propertyKey":"Door state","newValue":22,"metadata":{"readable":true,"min":0,"ccSpecific":{"notificationType":6},"max":255,"label":"Door state","secret":false,"writeable":false,"type":"number","stateful":true,"states":{"22":"Window/door is open","23":"Window/door is closed","5632":"Window/door is open in regular position","5633":"Window/door is open in tilt position"}},"commandClass":113,"prevValue":23,"propertyKeyName":"Door state","endpoint":0,"propertyName":"Access Control","property":"Access Control","commandClassName":"Notification","value":22,"ts":1793143990547}]}' to [[name:contact, value:open, descriptionText:Garage Door Sensor was opened]]
debug
parsed '{"cc":113,"cmd":5,"ep":0,"values":[{"ccVersion":8,"newValue":0,"endpoint":0,"metadata":{"readable":true,"min":0,"max":255,"label":"Alarm Type","secret":false,"writeable":false,"type":"number","stateful":true},"propertyName":"alarmType","commandClass":113,"property":"alarmType","commandClassName":"Notification","value":0,"prevValue":0,"ts":1793143990532},{"ccVersion":8,"newValue":0,"endpoint":0,"metadata":{"readable":true,"min":0,"max":255,"label":"Alarm Level","secret":false,"writeable":false,"type":"number","stateful":true},"propertyName":"alarmLevel","commandClass":113,"property":"alarmLevel","commandClassName":"Notification","value":0,"prevValue":0,"ts":1793143990540},{"ccVersion":8,"propertyKey":"Opening state","newValue":1,"metadata":{"readable":true,"min":0,"ccSpecific":{"notificationType":6},"max":255,"label":"Opening state","secret":false,"writeable":false,"type":"number","stateful":true,"states":{"0":"Closed","1":"Open"}},"commandClass":113,"prevValue":0,"propertyKeyName":"Opening state","endpoint":0,"propertyName":"Access Control","property":"Access Control","commandClassName":"Notification","value":1,"ts":1793143990542}]}' to [[name:contact, value:open, descriptionText:Garage Door Sensor was opened]]
dev:2722026-10-27 6:33:10.594 pm
info
info
dev:2722026-10-27 6:33:10.589 pm
debug
NotificationReport cmd:NotificationReport(v1AlarmType: 0, v1AlarmLevel: 0, notificationStatus: 255, notificationType: 6, event: 22, sequence: false, eventParametersLength: 0, eventParameter: [], sequenceNumber: 0)
debug
dev:2722026-10-27 6:29:41.617 pm
warn
description logging is: true
dev:2722026-10-27 6:29:41.616 pm
warn
debug logging is: true
dev:2722026-10-27 6:29:41.612 pm
info
updated...
