Hey guys, I need your help. Two things that are related.
One, Iām dipping my toes in the water of Virtual Devices and am not feeling any water. Either I donāt understand them or theyāre not working.
I created a Virtual Device and give it the type āSingled Element Classicā (I have a few of these). I hit āSave Preferencesā and āSave Deviceā. I now think I can click the On or Off button for that device under Devices and see (in the Current States and/or State Variables) that the virtual device is āonā or āoffā. Ditto that I could key in a level of (e.g.) 65 and click Set Level and see that level reflected in the Current States and/or State Variables. No Joy. What am I missing? Maybe thereās something wrong with the driver for Singled Element Classic. So I try the same test with type = Generic Z-Wave Dimmer. Same result (or lack thereof).
[By the wayā¦ my Hub is a C-5, if that makes a difference.]
[By the way, part II - I have a C-7 to swap in for the C-5. I donāt want to try to swap it in and lose everything. If Iām going to have to invest a ton of time doing this I want to plan when I do that. So I reached out to Hubitat Support to ask where the official answer is to āwhatās the best/recommended way to migrate from a C-5 to a C-7ā. Alas, crickets.]
Two, Iām doing this (virtual device stuff) because I have two of these bulbs (Singled) in two different lamps and it would be convenient if I could just have them behave as a single lamp. I want the ability to control ON and OFF, of course, but also level. Iāve tried a number of different ways to make this happen. Iāve used the Mirror app. I tried rules. Iāve tried the Virtual Device (per above) with a rule or mirror. I have a switch (sadly a switch and not a dimmer, for now) with a rule. Iāve had varying degrees of success but not complete. Whatās the recommended way to do this?
Thanks!
Scott
