Are they ZigBee devices? If so check under settings and make sure your ZigBee radio is still on. Mine turned off on me for some reason a few weeks back.
Yeah I should have mentioned that... they are all Zigbee... I'll look but since everything else works... like my peanut plugs and other hardwired zigbee devices...doesnt that mean the radio is on still?
Ya. If other ZigBee devices still work then that probably isn't it. Was just taking a guess.
You could also force a ZigBee repair by turning it off for 30 mins or so and then turning it back on and let them start to repair the mesh. Will take a while for them to repair though. Sometimes up to a day.
Another thing is to make sure you have the latest firmware.
Weird problem though. I usually hear this more with the Xiaomi devices.
@kv1 you likely had some interference in you network that knocked them all off probably caused by you or your neighbors wifi.
What zigbee and wifi channels are you using?
Do you have anything to scan your network with? (such as a Xbee or maybe in your wifi router settings unifi routers have a wifi scanner)
It looks like overnight things might have shaped up.. The cat stole one of the sensors off my desk and can't find it but the remaining one and the buttons all around the house seem to work again.
I hate when this sort of intermittent thing happens
I've had this happen a time or two. I usually try and wait it out. 24 hours and nothing improves I send a ticket in. It comes with a helpless feeling of "did I change anything?"
