If you are unfamiliar with Tasmota it is worth a look. A device loaded with Tasmota has it's own Web interface and operates entirely locally via WiFi but can be integrated with Hubitat.
A bulb looks like this for example:
In Hubitat it looks like this:
A power monitored plug looks like this.
Hubitat drivers can be found here: ([RELEASE] Tasmota Sync - Native and Real-time Synchronization between Hubitat and Tasmota 11 or later).
If you are not too techy and just want to buy devices with Tasmota on them there is a list maintained here. Here is an online store with a decent number of devices pre-flashed with Tasmota, Athom. If you don't mind digging deeper there is a broad range of devices that can be flashed with Tasmota with varying levels of difficulty.
Tasmota devices are suited to devices that are permanently plugged in. In my house I have bulbs, switches, plugs, power monitoring, fan control and sensors all tied into Hubitat. For battery operated devices, mainly sensors, I use Zigbee.
Good luck.
