Just raised a support ticket with the following, but maybe one of you fine fellows can cast a little light on this one. It's all very odd, because it's been working perfectly up until today:
Hey gang.
So... all was going pretty well, until I tried adding a bunch of new zwave devices this afternoon.
The first paired without too much trouble (an Aeotec Multisensor 6), but the second, identical sensor refused to. The discovery wheel goes around and around, and nothing gets found.
I moved on, and tried a contact sensor (also Aeotec). No dice.
I rebooted the hub. Still no dice.
Powered down the entire hub, and restarted it, and it was prepared to pair the contact sensor. But another, different Multisensor won't pair with it, either.
So... it's looking (unscientifically), like I can add at best one zwave device per hub proper power-cycle. That's not as designed, I'm sure, and it's not as it's been until now.
Sadly, though... I can't find anything in the way of diagnostics for this sort of thing... and being a command-line sort of person myself, that's rather frustrating.
My username is 'hubitat@ourhouse.org.uk'. Is there any guidance you can suggest, or diagnostics you can get to that I can't already see?
In terms of additional information, I've tried pairing these things at the outer reach of my systems, but they also fail to pair when they're literally sat on top of the hub
Thanks for any help you can provide!
Best Regards,
Jules
