Is there a way to trigger a rule based on the info coming from an email such as the Subject line or the TO or FROM?
I have a mailbox door sensor that sends a message to an email address. I use this to speak a message and turn on a color bulb so I know the mail has arrived.
Yeah...but there has to be something reading your email to perform that function, right? I believe that's what he's asking about. The only thing that I know that can do this that is compatible with HE is either IFTTT or Stringify. I do this for package notifications. When a package is delivered UPS, USPS or FedEx sends an email. My GMAIL applies a label to the email and Stringify detects that I've received an email with that label and execute a cloud endpoint that I've built in Rule Machine.
The reason I use stringify instead of IFTTT is that with Gmail, IFTTT would sometimes take up to 2-3 hours to pick up on the email. Stringify is almost instantly.
That said, why not simply replace the mailbox sensor with one that is directly compatible with HE? Either a tilt or contact sensor would be a lot more effective a trigger for your announcement.
Thanks everyone. Ryan780, I have tried all those and the distance is just to far and most times the response from the sensor doesn't get to the system. I have a mailbox unit that has a 400ft range and it is outside the mailbox and is intended to do so. I just need a way to read the subject line or the from line.
I use android so I will go look at tasker and stringify.
