Hello all,
Quick and easy solution for users with running RPi (e.g. for OpenVPN purposes).
Tested on Rapsberian (RPi3 - python3) out of the box:
- open terminal
- create folder structure in home/pi: home/pi/scripts/cgi-bin
- goto /home/pi/scripts/cgi-bin
- create python script sendmail.py
$ sudo nano sendmail.py - add following content:
#!/usr/bin/python
import smtplib
import cgi
fs = cgi.FieldStorage()sender_email = "xxxxxhub@gmail.com" receiver_email = "xxxxx@gmail.com" if "subject" not in fs or "body" not in fs: SUBJECT = "Default Subject" TEXT = "Default body text" else: SUBJECT = fs["subject"].value TEXT = fs["body"].value message = 'Subject: {}\n\n{}'.format(SUBJECT, TEXT) try: server = smtplib.SMTP_SSL('smtp.gmail.com', 465) server.login(sender_email,'<sender password>') server.sendmail(sender_email, receiver_email, message) server.quit() print 'Email sent!' except: print 'Something went wrong...'
Sender and receiver can be dynamic same like subject and body
set execution rights
$ sudo chmod +x sendmail.py -
run CGI HTTP sever (details on 20.20. CGIHTTPServer — CGI-capable HTTP request handler — Python 2.7.18 documentation)
$ python -m CGIHTTPServer 8000
server MUST be started from /home/pi/scripts/ to be able find sendmail.py script -
gmail setup:
I've created additional gmail account for this purpose xxxxhub@gmail.com
Allow less secure apps access for this account: https://myaccount.google.com/lesssecureapps?pli=1 -
Open browser on local network with this URL (use ip-address of RPi):
http://192.168.x.x:8000/cgi-bin/sendmail.py?subject=Hub+Warning&body=Motion+sensor+in+the+kitchen+has+been+activated
email should appear in receiver inbox.
You can check the log in terminal where server is running:
In Rule machine use HTTP GET request with upper URL link to send email according to trigger.
That's all.
Majomitto.
