Is it possible to create a rule that tracks the last button pressed on a keypad so that I can create a trigger which will run based on the button that was pushed?
I have a few Lutron keypads that have raise/lower buttons (similar to the Picos), and what I'm trying to do is if I press 'Lamp-1' last on the keypad, pressing the Raise/Lower buttons will trigger this last button pressed (Lamp-1) to raise/lower dimming. If the last button pressed was 'Shade', then similar behavior to raise/lower.
This is built into RadioRa2 keypads, but they lock the buttons to either 3rd party system (sonos) or lighting. No way to have both work at the same time, which is where Hubitat comes in.
I have everything work individually well for light dimming (and also Sonos Volume with these buttons), but trying to figure out how I can get Hubitat to 'remember' the last button pressed.
Thanks for any ideas!
