Tried to add a Pico Remote and get a "Cannot get property value on null object value on line 124"
I went to add a Lutron Pico Remote to Hubitat. I successfully added it to the Lutron app. Then went to add the Pico to the Hubitat Lutron Integrator. During that process I couldn't get into the app any longer. The error in the logs states errorjava.lang.NullPointerException: Cannot get property 'value' on null object on line 124 (method mainPage). Any suggestions?
All of this is unhelpful, and gives the impression that you’re pulling things out of the air. Your response suggests you don’t have any Lutron devices. Why not let those who have such devices step in and help?
Please see PM I just sent you about how to resolve this.
Hi, what is the solution on this? Im now having a same problem. Thanks
Restoring a recent backup resolved this.
I performed a restore and the issue resolved.
:question:
Hmm, I have had no problems adding Pico Remotes, I recently removed a Lutron Maestro dimmer and reprogrammed it to control a Zooz Zen77 Dimmer but I suspect you used the wrong variables or assignment within the app. Do a restore. Get the list from the Lutron hub and try again. Lutron integration is a bit tricky to set up.
OpenWeather? I think you are responding to the wrong subject area.
