I've wanted to know when the garbage man came, although it's actually fairly predictable.
Anyway, I taped an Ecolink tilt sensor in a plastic bag to the underside of the recycle can lid. Works at the end of a long driveway with intervening trees. We'll see if it works in real life.
I’ve been thinking about doing something like this. I have spare Ecolink tilt sensors that I had modified to use mercury bulb switches but never put in service. (replaced with a solid state one that has been working perfectly for a couple of years.) Definitely worth a try. I had assumed the range was not sufficient.
Since when did home automation things have to make any sense?
I would do it to prevent a long walk down to the street only to find out that 1) the garbage truck is running late today, or 2) there was no pickup because it was George Birthington’s Wash Day or some such.
Not far removed from why I have a motion sensor in the mailbox.
More than one good reason for that! Lid G-Forces, device stink, and device flight are just three.
If this works in prototype then he ought to get a project box and epoxy it onto the can just under the handle. This will afford protection and radio range improvement pointing back to the house.
Then count the days before the pickup service, or somebody else, calls the B_mb Squad
