For the most part, I no longer touch or change my HE device.
for no obvious reason, I have 4 sengled CT bulbs in the hallway. I have been using the Advanced Zigbee CT Bulb driver for all 4 bulbs since I installed them more than 2 months ago.
I began seeing an error message for a divide by zero
I played around and could cause the error everytime by simple using the device panel to issue a colortemp change to something, such as 3000 or 4000. When I issue a colortemp change to 2000 (which is out of range for this bulb) the bulb goes to 2702. but a direct setting of the colortemp gives me an error.
I switched driver to Generic Zigbee CT bulb (dev). initially it was a bit flaky even after button mashing the 'configure'. I changed to 'Device' - cleared all - states, childs etc, then switched back to Generic and it cleared things eventually.
Once changed, the 'transition time' drop down was filled with 'Click to Set'. The choices are 500, 1, 1.5, 2 and 5. I set to 500MS. The resultant delay on the bulb was uncomfortable so I chose to turn it off.
When I returned to set 'Transition time' there is no '0' or off. If you select 'No Selection', it will jump to 1 second. There is no way to turn off this transition time.
Secondarily - if HE would care to push the dev driver to the public examples pile - it would be a great template for me to write my own driver for this bulb, while being able to add features I've added to my other drivers and fix the colortemp table as I have done for my other 2 CT bulb brands.
