Perhaps there is a real Zigbee Pro out there.
Question:
I must have deleted a Zigbee device, but it must still be connected somehow. I have the following line in the mesh output:
[null, 81D1], LQI:249, age:3, inCost:3, outCost:3
It's been persistently there for the last 2 weeks, so it must still be on.
Does anyone know how I can identify what this is? Or where it is?
In one case, I was able to find the device by using the "Device" tab, and putting it into list mode (the left button) instead of tile mode. I then did a CTRL-F and searched for that 4 digit string. In this case, I found the device and was able to pair it again. In this case it was an Iris motion V3 that had dropped off the network when I had the circuit breakers off, and apparently it lost the route through a powered device.
In a second case, I couldn't find that 4 digit string in any device. I made a virtual device, numbered it the same as that 4 digit string, and made it a generic Zigbee switch. (Mike Maxwell method) I then deleted the rogue device. At that point I was able to figure out what wasn't working any more. It was a Xiaomi vibration sensor in this case. It was weird because it seemed to be communicating with the hub, but somehow the ID number had changed. When I re-paired it, this device came back in with the proper working ID and all was good. I don't know what happened exactly, or how the device was able to change its ID and back again?
