Did you find a good replacement?
Thanks,
Thanks,
The Osram Zigbee buttons are quite good.
https://www.amazon.co.uk/gp/product/B074PZLX2Y/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Or Smartthings buttons, or Xiaomi, although read up on those as some have had issues with them staying on the network.
Does it connect without ifttt?
Yeah direct to HE.
As well as using pushed and held, so effectively 8 buttons in 1
They were £14 so maybe worth watching the price
I went with the SmartThings v2 buttons. Work great!
My only issue with them was cost, they're £25 over here. I can get 4 Xiaomi for the price of that
They are expensive here too. But 5-6x a year Amazon lowers them down to $8-10. That is when I purchase.
Does anyone know of a multifunction button like the pop that works well?
Most buttons do. They have Pushed, Double push (in the case of Xiaomi up to 5 pushes), and hold etc. So you can map different fuctions to the push (or double) or hold etc, and some you can do on release too.
The Osram gives you Push, Hold and release. Each can be used as triggers in many apps (ABC, RM etc).
I think with the pop, you can use 3 functions from memory, so all the above can cover those.
You also have the opportunity to use Philips Hue button controllers directly connected to Hubitat
Good grief, how did I forget those!
Jesus man!
I even wrote us an app for them!
I'm sorry boss
I'll get my coat........
Pmsl
awesome thanks for the clarification. I am just starting with HE after many years integrating with Smartthings and webcore.
Thanks for the help, seems like this is a great enthusiast community!
Pico by the bed (black, so Bruce’s label method won’t work). Controls the bedroom lights, locks the doors and shuts down the house.
Xiaomi under a side table in the living room next to the chair I usually sit in. Controls Door lock and unlock, floor lamp across the room, lamp next to me, dining room lights, kitchen light, and shuts the house down.
How do I remember? I just do. How does the rest of the family remember? They don’t use them. I put a pico right by the back door that I use all the time, and my wife always tells the Echo that’s right next to it to do the same thing the Pico does. 🤷🏼
Haha. Same here. Have a remotec scene controller by the bed. Currently running 19 different things, and I know every one
Thanks for the advice.
Our house has about 10 pop buttons, hue lights, GE (jasco) dimmers and a bunch of other iot. To avoid cost, i tried some interesting configurations and found one that is livable.
It seems that HUE bulbs trigger quickly. To keep the latency down, i have set up the pop switches to trigger hue lights within its own config and call IFTT for fans and other dimmers. It isn't the best solution, but it is livable.
But.. just in case, as i'm sure most of us here do, i just ordered a button from smartthings
Has anyone found any decent wall plates for the smartthings button?
I'll check back in after the next config.
This should arrive soon.
Zigbee 3.0, but it’s Xiaomi so I’m not holding my breath for completely compliant, but hopefully it is.
I’m going to try it in on HE first. Maybe a driver would not be too hard for those with the skills. I know it will work with my Xiaomi Aqara Hub, but having multiple button presses in HE directly would be very nice.
looks nice, let me know what you think and if you can hack a driver together.
