TKB Home TZ56S switch
Hi all,
I'd like to ask if you have experiences to include/pair TKB Home TZ56S single switch with Hubitat C7.
I put Hubitat C7 into z-wave inclusion mode and press 3x the off button on mentioned switch but nothing happens. Please share me your experiences in case you have some.
Thanks in Advance
Do the region/frequency for your hub and the device match?
Hub is in Settings > Z-Wave Details. The device will often have it printed on the device or at least available in the manual or other documentation.
Hubitat C7 -> EU - 868.4 MHz
TKB Home TZ56S -> 868.42 MHz
That looks good.
Have you tried an exclusion before inclusion?
yes, tried already also to reset device.
Does the exclusion succeed? You should see a message on your screen if so.
In both cases (inclusion and exclusion), keeping Logs open while doing so is likely to give additional clues.
Inclusion/Exclusion does report any info related to the TKB Home switch.
Seems to be that switch z-wave is dead :frowning:
