@ATLWorkshop @Madcodger
I would like to suggest, using the following switch , if all you want is a simple timer:
I have only passing familiarity with Konnected, but may try it once this guest season is over. Thanks for the suggestion!
In previous homes I used an Elk M1 Gold system, and loved it in both locations. But no local alarm companies could support it in our rural area, and as I get older I think more about how my wife would need to have things maintained if I'm out of the picture, so I opted for a more "conventional" system, maintained by the largest alarm company in our area, Expensive JUNK, in my view. More problems in the past two years than I had with my Elk systems in two homes and nearly 20 years. Anyway, despite that, it should work with Konnected, so that's the likely path. Thanks again.
